[GeoNode-devel] GNIP: GeoServer A&A Improvements
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Nov 11 05:37:22 PST 2016
Dear all,
I created two branches on GeoNode fork with a first implementation of
Advanced Authentication & Authorization between GeoNode and GeoServer.
Basically with those improvements the A&A communication system between
GeoNode and GeoServer has been improved in order to keep the two frameworks
more independent and avoid using the cookies which may cause issues
sometimes.
Other than this, we introduced the GeoFence[1] plugin into GeoServer which
provides more granular control of the data access rules.
How to test the stuff:
1. Clone the branch "GN_ADVANCED_SECURITY" of GeoNode
    https://github.com/GeoNode/geonode/tree/GN_ADVANCED_SECURITY
2. Get the GeoServer-GeoNode extension for GN_ADVANCED_SECURITY
    You can either
     - Clone the branch "GN_ADVANCED_SECURITY" of GeoServer-GeoNode-ext
https://github.com/GeoNode/geoserver-geonode-ext/tree/GN_ADVANCED_SECURITY
     - Download the WAR and GeoServer Data Dir from
http://build.geonode.org/geoserver/latest/
       http://build.geonode.org/geoserver/latest/geoserver-2.9.x-oauth2.war
       http://build.geonode.org/geoserver/latest/data-2.9.x-oauth2.zip
3. Compile the documentation locally with sphinx[2]
    cd <geonode_GN_ADVANCED_SECURITY>/docs
    make html
4. Refer to the documentation and follow the guide
    <geonode_GN_ADVANCED_SECURITY>/docs/_build/html/index.hml
    and go to
     "Docs » Tutorials » Administrators Workshop » GeoNode and GeoServer
Advanced Security"
 tutorials/admin/geoserver_geonode_security/index.html#geoserver-geonode-aa
Please notice that this is still a work in progress and it is not yet
stable.
Any feedback and comment is much appreciated.
Best Regards,
Alessio Fabiani.
[1] - https://github.com/geoserver/geofence
[2] - http://www.sphinx-doc.org/en/1.4.8/
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161111/cef54c4d/attachment-0001.html>
More information about the geonode-devel mailing list
