[GeoNode-devel] Geonode using localhost for WMS requests on Ubuntu 16.04
Simone Dalmasso simone.dalmasso at gmail.com
Sun Nov 13 23:38:49 PST 2016
Hi, the command "geonode" is available only if you install geonode using
the apt package.
thanks for the PR
2016-11-14 8:10 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
> Thanks for the clues guys.
> Francesco did you mean “python manage.py updatemaplayerip” rather than
> "geonode updatemaplayerip"?? The latter is not a command on geonode 2.4
> afaik.
> Anyway I just deleted my existing layers, and setting SITEURL to the
> actual server name (http://www.example.com/) in local_settings.py and
> restarting apache2 did indeed fix thumbnails for new layers.
> I read the doco <http://the%20doco> as saying to set SITEURL to http://localhost/ so maybe that could be updated:
> Change the value of the SITEURL:
> SITEURL *=* "http://localhost/"
> Have made pull request #2714 with this small doco change.
> Cheers
> Jonathan
> *From:* Francesco Bartoli [mailto:xbartolone at gmail.com]
> *Sent:* Friday, 11 November 2016 7:36 PM
> *To:* Simone Dalmasso
> *Cc:* Jonathan Doig; geonode-devel at lists.osgeo.org
> *Subject:* Re: [GeoNode-devel] Geonode using localhost for WMS requests
> on Ubuntu 16.04
> Hi,
> For the existing ones doing the command "geonode updatemaplayerip" should
> fix the rest.
> Il giorno 11/nov/2016, alle ore 07:43, Simone Dalmasso <
> simone.dalmasso at gmail.com> ha scritto:
> Hi,
> Fixing the settings is correct and will fix layers and new maps. However
> for existing maps you have either to adjust the URL in admin maplayers or
> recreate the map. Thumbnails can be generated too via edit layer/map page.
> Il venerdì 11 novembre 2016, Jonathan Doig <j.doig at unsw.edu.au> ha
> scritto:
> Hi devs
> I’ve installed Geonode 2.4 on Ubuntu 16.04 following these instructions
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>
> and changing where needed to make it work.
> However Geonode fails to display layers because the browser is making WMS
> requests to “localhost” rather than to my site URL.
> I’ve fixed the maps in the individual layer pages by changing the
> OGC_SERVER default PUBLIC_LOCATION in local_settings.py from
> http://localhost/geoserver/ to http://<my_server>/geoserver/
> I don’t know why that was needed though, it’s not in the installation doco.
> In any case the thumbs and legend graphics are still broken e.g.:
> http://localhost/uploaded/thumbs/layer-4151fb58-a7bb-
> My Geoserver uses the correct URL for WMS calls.
> Advice please.
> Thanks
> Jonathan Doig
> Simone
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161114/b7bacefb/attachment-0001.html>
More information about the geonode-devel mailing list
