[GeoNode-devel] Geoserver retains old admin passwords
Simone Dalmasso simone.dalmasso at gmail.com
Fri Nov 18 01:05:37 PST 2016
Hi, just a clarification on the passwords.
The default admin/geoserver password (which has to be changed) is used only
for internal communications between geonode and geoserver and should never
be used by any user or administrator. It can be changed through the
geoserver UI, but geonode needs to know it anyway and this is the reason
why you find it in the OGC settings.
The administrator passwords as well as other users passwords are stored in
geonode and are used for permissions and authentication across all the site.
2016-11-18 4:53 GMT+01:00 j.doig at unsw.edu.au <j.doig at unsw.edu.au>:
> Hi all
> Thanks for your reply Alessio.
> After some sleuthing I’ve found that within a Geonode installation
> Geoserver allows 3 different passwords for admin login:
> 1.      *Geonode admin password*
> ·        Set by python manage.py createsuperuser, changed via Geonode GUI
> ·        Stored encrypted in the geonode:people_profile table in postgres
> 2.      *Geoserver admin password*
> ·        Changed via Geoserver admin GUI
> ·        Stored encrypted in /var/lib/tomcat7/webapps/
> geoserver/data/security/usergroup/default/users.xml
> 3.      *Geonode OGC Server default admin password* (‘geoserver’)
> ·        Stored as OGC_SERVER['default’][‘PASSWORD’] as plain text in
> /home/geonode/geonode/geonode/local_settings.py
> ·        Changed by editing this file and restarting Apache
> This is confusing and potentially risky, as you can change a compromised
> password in one place (Geonode or Geoserver) not realising it still works
> because it’s also stored in the other place.
> I’ve raised this as issue #2715
> <https://github.com/GeoNode/geonode/issues/2715>.
> For one thing, the installation package, and manual install doco
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>,
> should include a step to change the default password in local_settings.py.
> I've included that step
> <https://github.com/UNSW-CFRC/geonode_install/blob/master/install_geonode/9.1_add_apache_geonode_config.yml#L27>
> in my own Ansible playbook for Ubuntu 16.04.
> Regards
> Jonathan
> *From:* alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com] *On
> Behalf Of *Alessio Fabiani
> *Sent:* Tuesday, 15 November 2016 8:12 PM
> *To:* Jonathan Doig
> *Cc:* geonode-devel at lists.osgeo.org
> *Subject:* Re: [GeoNode-devel] Geoserver retains old admin passwords
> Hello Jonathan,
> GeoServer makes use of two different Authentication types: Basic Auth
> (used by the backend for the import operations and changes to the catalog),
> GeoNode-Cookies Auth (used to provide access to the GeoServer resources to
> the GeoNode users).
> In order to change the GeoServer Basic Auth admin password, you must login
> into the GeoServer page using an admin user, go to Security > User, Roles,
> ... and manually update the admin user password.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Nov 15, 2016 at 8:24 AM, Jonathan Doig <j.doig at unsw.edu.au> wrote:
> Hi all
> My Geoserver, inside Geonode 2.4 on Ubuntu 16.04, won’t let go of old
> admin passwords.
> I used manage.py createsuperuser to set the Geonode admin password when I
> did my manual install. Pretty sure that password then worked for logging
> into Geoserver as admin also.
> I’ve since changed the Geoserver admin password through the UI, twice, and
> also done so by calling manage.py changepassword directly and from ansible.
> In total I’ve used 2 new passwords. Both passwords, and the original one
> ‘geoserver’, now work when logging in as admin. Other random passwords do
> not.
> It’s not entirely clear but this may be the behaviour reported back in
> September in this post:
> http://osgeo-org.1560.x6.nabble.com/Geo-server-Admin-
> Password-td5286411.html
> Jonathan
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161118/727703d3/attachment.html>
More information about the geonode-devel mailing list
