[GeoNode-devel] GNIP 48: Supports for any spatial reference system in viewers
Paolo Corti pcorti at gmail.com
Fri Oct 7 13:32:24 PDT 2016
Thanks Daniel
which viewer are you planning to upgrade? GeoExplorer?
Regarding polar projections I see that ol2 support them using proj4js (
http://dev.openlayers.org/examples/polar-projections.html). I would expect
the same for ol3, but I had never the chance so far to use it
cheers
p
On Thu, Oct 6, 2016 at 5:31 PM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> Paolo,
> Ariel and I will be working on a GNIP for upgrading the viewer from ol2 to
> ol3 that would other for client raster projections. We should verify if the
> ol3 raster reprojection supports polar projection.
> Dan
> On Thu, Oct 6, 2016 at 3:36 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi developers
>> There is interest here (copying my colleague Josh Lieberman and Ben
>> Lewis) to have a GeoNode instance visualizing data using the Polar
>> Projection.
>> More generally, we think GeoNode should support rendering of datasets
>> using any supported SRS by GeoServer (currently the viewers supports
>> only 900913 and 4326 as far as I can see).
>> Therefore we created a GNIP with such a purpose:
>> https://github.com/GeoNode/geonode/wiki/GNIP-48--Supports-
>> for-any-spatial-reference-system-in-viewers
>> The effort should be limited, I already made some tests, as documented
>> in the GNIP itself.
>> So it would be awesome to have the GNIP approved and maybe implemented
>> for GeoNode 2.5
>> thanks
>> p
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161007/d2d5c04c/attachment.html>
More information about the geonode-devel mailing list
