[GeoNode-devel] [Incubator] MOTION: GeoNode Graduation from OSGeo Incubation
Ariel Nunez ingenieroariel at gmail.com
Fri Oct 21 05:35:42 PDT 2016
Thank you Angelos!
On Oct 21, 2016 5:03 AM, "Angelos Tzotsos" <gcpp.kalxas at gmail.com> wrote:
> Hi all,
> Since there is a -1 on the table about our OSGeo incubation, I would like
> to volunteer to compile a Release Procedure that is up to the standards of
> the incubation committee.
> Best,
> Angelos
> On 09/04/2016 01:25 AM, Cameron Shorter wrote:
> Hi all,
> I've just checked the check list. GeoNode looks to be in great shape. I'd
> also like to comment that through my involvement packaging GeoNode on
> OSGeo-Live that we have seen a responsive and health community project.
> However, it seems there isn't a link to the release process here:
> https://wiki.osgeo.org/wiki/GeoNode_Incubation_Checklist#Release_Procedure
> So I'm currently -1 on graduation till answers are added to the Release
> Procedure. (I'm assuming this is just an oversight).
> While not approved by the incubation committee, I have added suggestions
> for a next version of the incubation list here:
> https://wiki.osgeo.org/wiki/Project_Graduation_Checklist
> While nothing on this list should prevent current incubation, I suggest
> running your eye over it and see if there is anything else worth
> addressing.
> In particular, I suggest that somewhere in your processes you link to the
> OSGeo code of conduct.
> On 2/09/2016 2:59 PM, Jody Garnett wrote:
> You are correct David, twice:
> - incubation finding issues is the point, we do not ask that the issues
> are fixed during incubation only that they are listed as known problems (so
> potential users are aware and can decide to help out or steer clear as
> appropriate).
> - none of the issues I found were that interesting, indeed my check went a
> bit further then I was able to email (for example confirming with Jeff that
> the sample data was obtained under asuitable license)
> That said I would applicate an extra set of eyes on the checklist, I am
> interested in any work that needed to be done during incubation (such as
> you updating the headers - although I guess that was due to the code
> changing ownership).
> It is my hope to continue working through the checklist and respond with a
> firm +1, currently I am at an enthusiastic +0 :)
> Jody Garnett
> On 30 August 2016 at 09:07, David William Bitner <bitner at dbspatial.com
> <mailto:bitner at dbspatial.com> <bitner at dbspatial.com>> wrote:
>     Just to bump this a bit as many were traveling when the motion
>     went out.
>     The GeoNode team is actively addressing the concerns that Jody
>     brought up, all of which are valuable items, but I do not believe
>     any are showstoppers. If there are any additional concerns, please
>     bring them up here.
>     Here is the current status on votes:
>       * Bruce Bannerman
>       * Bob (CI-StPaul) Basques +1
>       * Landon Blake +1
>       * Howard Butler
>       * Arnulf Christl +1
>       * Jody Garnett (chair)
>       * Dimitris Kotzinos
>       * Tom Kralidis +1
>       * Julien-Samuel Lacroix +1
>       * Mark Lucas
>       * Steve Lime +1
>       * Daniel Morissette
>       * Markus Schneider
>       * Cameron Shorter
>       * Jeroen Ticheler
>       * Norman Vine
>       * Frank Warmerdam
>     On Tue, Aug 30, 2016 at 8:09 AM, Julien-Samuel Lacroix
>     <jlacroix at mapgears.com <mailto:jlacroix at mapgears.com>
> <jlacroix at mapgears.com>> wrote:
>         +1
>         Julien
>         On 2016-08-25 11:28 AM, David William Bitner wrote:
>             Dear Incubation Committee,
>             As the mentor for GeoNode Incubation, I would like to make
>             a motion to
>             graduate GeoNode from the OSGeo incubation process with
>             Jeff Johnson to
>             act as the Project Officer.
>             You will find the Incubation Checklist at:
>             <https://wiki.osgeo.org/wiki/GeoNode_Incubation_Checklist>
>             During the incubation process much work has been done to
>             solidify the
>             intellectual property behind GeoNode.
>               * copyright was transferred from the now dissolved OpenPlans
>               * a Contributor License Agreement has been adopted and a
>             process
>                 created to collect from all contributors
>               * all files have been checked for headers
>               * the release process documentation has been shored up
>             GeoNode has a tremendous "bus quotient" as there are core
>             developers
>             distributed globally. Many of the institutional direct
>             users have
>             developed strong expertise in GeoNode along with many
>             companies that
>             have developed support programs built around GeoNode.
>             There is no single
>             point of failure for this project.
>             The GeoNode has managed to work in the open from inception
>             in a way that
>             has enabled enormous amounts of collaboration both between
>             institutions
>             using GeoNode and companies/individuals providing support
>             for GeoNode.
>             Thanks,
>             David
>             dbSpatial LLC
>             612-424-9932 <tel:612-424-9932> <612-424-9932>
>             _______________________________________________
>             Incubator mailing list
>             Incubator at lists.osgeo.org <mailto:Incubator at lists.osgeo.org>
> <Incubator at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/incubator
>             <http://lists.osgeo.org/mailman/listinfo/incubator>
>         --         Julien-Samuel Lacroix
>         T: +1 418-696-5056 #202 <tel:%2B1%20418-696-5056%20%23202>
> <%2B1%20418-696-5056%20%23202>
>         Mapgears
>         http://www.mapgears.com/
>     dbSpatial LLC
> Incubator mailing listIncubator at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/incubator
> Angelos Tzotsos, PhD
> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161021/0949ab98/attachment-0001.html>
More information about the geonode-devel mailing list
