[GeoNode-devel] [geoserver-geonode-ext] config.yaml Add Border to printed Map, add Tiles
Jeffrey Johnson ortelius at gmail.com
Fri Oct 21 08:48:02 PDT 2016
This is based on the MapFish printing module. Take a look at the docs here.
http://www.mapfish.org/doc/print/configuration.html
On Fri, Oct 21, 2016 at 8:35 AM, Martino Boni
<ing.martino.boni at gmail.com> wrote:
> Dear all,
> I have started using GeoNode for my project and I’m trying to customize a
> bit the layout of the printed pdf using:
> https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/webapp/data/printing/config.yaml
>  I’d like to add a border to the image map printed and moreover I can’t see
> the tiles underneath the vector/raster layers I’m printing.
>  Can I ask you some hints on how to set up properly the config.yaml and how
> to print also the baselayer's tiles?
>  Thanks in advance for your time,
>  Regards,
> Martino Boni
> Cell Italy:  (+39) 347 4719741
> P Please consider the environment before printing this e-mail.
> TRATTAMENTO DATI PERSONALI - LEGGE SULLA PRIVACY D.LGS.196/2003
> Il contenuto di questa mail è strettamente confidenziale e riservato. Se
> ricevete questa mail per errore, siete invitati a distruggerla
> immediatamente senza farne copie, e ad informarci cortesemente per telefono,
> fax o e-mail. Qualora non desideriate ricevere in futuro comunicazioni della
> scrivente potete esercitare i diritti previsti dall'art. 7 della Legge
> 196/2003 inviando un messaggio di posta elettronica all'indirizzo del
> mittente.
> According to Italian law D.L. 196/2003 concerning privacy, if you are not
> the addressee (or responsible for delivery of the message to such person)
> you are here by notified that any disclosure, reproduction, distribution or
> other dissemination or use of this communication is strictly prohibited. If
> you have received this message in error, please destroy it and notify us by
> email.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
