[GeoNode-devel] Question about GeoNdoe Layer "view" and "download" permissions
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Oct 24 09:16:33 PDT 2016
Dear all,
I did not hear anymore comments on this, but what about the following
proposal?
We can distinguish between "view services" and "download services". In OGC
the "view services" are the ones related to mapping, like the WMS, while
the "download services" are the raw ones, like WFS and WCS. This is also
the mapping that INSPIRE does over OGC.
What I propose is to:
1. If a user has "view" permissions he can access to maps and portryals,
i.e. he can access to the WMS service.
2. If a user has "download" permissions he can access to raw services like
WFS for vectorial data and WCS for raster data, i.e. he can download Layers
as Shapefiles or GML2 or GeoTIFFs.
The two permissions will be separated.
Also the Download Page must be revised. It must have two TABS, one for
WMS-like downloads (PNG, JPEG, GIF) and one for W*S-like ones (Shapefiles,
GML2, GeoTIFF, ...).
Hope what wrote is clear enough. Feel free to ask for details and or
clarifications.
Thoughts?
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Oct 20, 2016 at 1:29 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Ciao Alessio,
> I think it could make sense to enforce such constraint also adding other
> permissions like edit_metadata etc. It would require some work on the ui so
> that the user is aware of what's going on.
> 2016-10-20 13:07 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Dear all,
>> while working on this GNIP (GNIP: GeoServer A&A Improvements)
>> https://github.com/GeoNode/geonode/issues/2374
>> (which by the way has been updated allowing GeoNode and GeoServer to rely
>> on OAuth2 Protocol and GeoFence)
>> we are facing an "issue" trying to set layers' access rules accordingly
>> to GeoNode permissions.
>> Long story short, currently GeoNode allows a user to setup two different
>> kind of Layer access permissions:
>> 1. View permissions (the Layer can be visualized on map and is listed on
>> the GeoNode layers list)
>> 2. Download permissions (the Layer can be downloaded in several formats,
>> JPEG, PNG, PDF etc...)
>> While this is correctly handled on GeoNode side, I guess there are some
>> discrepancies on how this can be handled on the backend (GeoServer in this
>> case).
>> The thing is, if you can download a layer on the backend you necessarily
>> have also permissions to see it. Unless view and download use different
>> protocols (which is not the case) to download a layer a user must have
>> permissions to access it.
>> That means that even if in GeoNode we remove view permissions to a layer
>> but we leave download ones, the Layer won't be listed in GeoNode but it
>> will be always accessible from GeoServer.
>> I'm going to ask here, is it correct to maintain this logic? Should be
>> instead put more controls on GeoNode and make view permissions take
>> precedence on download ones (if you cannot view it you cannot download it
>> either)?
>> Thoughts?
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161024/ff3d95a9/attachment.html>
More information about the geonode-devel mailing list
