[GeoNode-devel] Opendeo Printing REST endpoint code
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 8 08:23:27 PDT 2016
The problem is that the 2.9.x version has different endpoints. Basically we
need to rewrite the GeoNode part also, since the internal REST calls are no
more recognized by GeoServer.
I'm going to open a JIRA.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Sep 8, 2016 at 5:21 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> https://github.com/boundlessgeo/geoserver-exts?files=1
> I'm +1 to remove this. It's not used as originally intended (full template
> based prints which I have a branch for somewhere) and is only used for
> thumbnails which we can find a different method.
> On Thursday, September 8, 2016, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Hi all,
>> someone knows where to find the source code of this REST endpoint used by
>> GeoNode?
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160908/340a170b/attachment-0001.html>
More information about the geonode-devel mailing list
