[GeoNode-devel] Communication between GeoServer and GeoNode fails
Michael Wagner mwagner at allspatial.info
Mon Sep 12 11:47:08 PDT 2016
Hi there,
Trying to change a layer's style in GeoNode leads to an error message "Error saving style" and the style is never changed. Checking the GeoServer logs shows the issue as follows:
WARN [geonode.security] - Error connecting to the GeoNode server for authentication purposes
org.springframework.security.authentication.AuthenticationServiceException: Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
at org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:62)
at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
The error occurs on Ubuntu 14.04 with GeoNode 2.4 and GeoServer 2.7.4./2.9.1. The full error log is attached to this email.
I also filed the issue on JIRA:
https://osgeo-org.atlassian.net/browse/GEOS-7737?filter=-4 <https://osgeo-org.atlassian.net/browse/GEOS-7737?filter=-4>
Many thanks for your support,
Michael
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160912/9e1e7e43/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160912/9e1e7e43/attachment.obj>
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160912/9e1e7e43/attachment-0001.html>
More information about the geonode-devel mailing list
