[GeoNode-devel] Update the BBOX of an existing layer
Simone Dalmasso simone.dalmasso at gmail.com
Wed Sep 14 01:09:06 PDT 2016
I see,
you would have to get the result of the recalculate function in geoserver,
if it returns one, and update the bbox in the resourcebase accordingly. I
suggest to use a ResourceBase.objects.filter(pk=layer.id).update() to do
that.
2016-09-14 9:35 GMT+02:00 Dimitris Karakostis <karakostis.dimitris at gmail.com
> Yiasou Tom,
> Thanks for your answer. I have also found out that the signal you
> mentioned does this. Instead of calling  layer.save(), I execute the signal
> directly in my application as:
> from geonode.catalogue.models import catalogue_post_save
> from geonode.layers.models import Layer
> layer = _resolve_layer(
>             request,
>             layer_name,
>             'base.change_resourcebase_metadata',
>             _PERMISSION_MSG_METADATA)
> instance = layer
> catalogue_post_save(instance, Layer)
> In my workflow, I have a layer with a specific BBOX. Then I add a new
> feature (e.g. a point), which is outside this BBOX. To add the point I send
> a WFS INSERT POST request. The point is added successfully and its visible
> in Geoserver (layer preview). I also send another request to "recalculate"
> the BBOX displayed in the layer's page in Geoserver.
> So my question is how to update the BBOX coords stored in the
> base_resourcebase table with the BBOX coords, which were recalculated in
> Geoserver.
> Executing the above signal it doesn't get the BBOX values from the
> geoserver but the ones from base_resourcebase so basically nothing is
> updated.
> I guess what I need to do is when I recalculate the BBOX for the layer in
> Geoserver, to pass these new coordinates to the base_resourcebase. But I
> can not figure out if there is a signal/function for this.
> On Wed, Sep 14, 2016 at 1:06 AM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
>> Yiasou Dimitris:
>> Some of GeoNode's CSW fields are ancillary fields which are managed via
>> signals as opposed to forms/views.
>> In the GeoNode Layer case, the Layer.csw_wkt_geometry would be the exact
>> field
>> to update (with WKT of course)
>> I'm not familiar with your exact workflow/use case, but when saving a
>> layer,
>> the signal in [1] should do this for you automagically given a
>> Layer.save() in
>> your calling application.
>> Hope this helps.
>> ..Tom
>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/catal
>> ogue/models.py#L42
>> On Tue, 13 Sep 2016, Dimitris Karakostis wrote:
>> Date: Tue, 13 Sep 2016 16:47:15 +0200
>>> From: Dimitris Karakostis <karakostis.dimitris at gmail.com>
>>> To: geonode-devel <geonode-devel at lists.osgeo.org>
>>> Subject: Re: [GeoNode-devel] Update the BBOX of an existing layer
>>> Hello!
>>> Any suggestions on this?
>>> On Thu, Aug 4, 2016 at 2:17 PM, Dimitris Karakostis <
>>> karakostis.dimitris at gmail.com> wrote:
>>> Some extra links on geoserver's RESTapi on the recalculate parameter:
>>>> http://docs.geoserver.org/stable/en/user/rest/api/featuretypes.html#
>>>> recalculate
>>>> and the layer_metadata view: https://github.com/wfp-
>>>> ose/geonode/blob/master/geonode/layers/views.py#L297
>>>> Thanks
>>>> Dimitris
>>>> On Thu, Aug 4, 2016 at 2:10 PM, Dimitris Karakostis <
>>>>> I am working on the development of a functionality where the user can
>>>>> add/edit the location of existing features (points etc.)
>>>>> When I add the new point then I use the <<recalculate>> parameter (from
>>>>> geoserver) in order to update the BBOX in the geoserver.
>>>>> But I can not find out how to update the BBOX stored in the CSW.
>>>>> I have found out, that if I manually update the layer's metadata, then
>>>>> the BBOX in the model is replaced with the correct one.
>>>>> But looking at the layer_metadata view, I am not sure, which is the
>>>>> function that actually does this.
>>>>> Can someone point me to the right direction?
>>>>> Thanks.
>>>>> Dimitris
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160914/35118b2d/attachment-0001.html>
More information about the geonode-devel mailing list
