[GeoNode-devel] Tests and timestamps with tzinfo
Paolo Corti pcorti at gmail.com
Tue Aug 1 08:17:14 PDT 2017
Hi
I agree, we should generate dates in tests using Python datetime library.
I believe that right now tests would fail when changing Django time
zone in settings
p
On Tue, Aug 1, 2017 at 11:01 AM, Cezary Statkiewicz
<cezary.statkiewicz at geo-solutions.it> wrote:
>  Hi,
>  I wanted to use tz-aware timestamps in GN, and set USE_TZ to True. I've
> noticed however that tests are failing after that, in setup code:
> in setUp
>    create_models(type='layer')
>  File "geonode/geonode/base/populate_test_data.py", line 206, in create_models
>    l.save()
>  File ".virtualenvs/geonode/lib/python2.7/site-packages/django/db/models/
> fields/__init__.py", line 1476, in get_prep_value
>    value = timezone.make_aware(value, default_timezone)
>  File ".virtualenvs/geonode/lib/python2.7/site-packages/django/utils/
> timezone.py", line 358, in make_aware
>    return timezone.localize(value, is_dst=None)
>  File ".virtualenvs/geonode/lib/python2.7/site-packages/pytz/tzinfo.py", line
> 309, in localize
>    loc_dt = dt + delta
> OverflowError: date value out of range
>  I've checked geonode.base.populate_test_data.create_models() and noticed that
> dates are fixed in code[1] to values like: 1900-06-03, 5000-11-01,
> 0001-01-01.. Is there any reason to have such values or can we generate dates
> dynamically there?
>  References:
>  [1] https://github.com/GeoNode/geonode/blob/
> 5e88f3d0d6601db5ca8099d28897098b125f01a6/geonode/base/
> populate_test_data.py#L102
>  Best Regards,
>  Cezary Statkiewicz
> Regards,
> Cezary Statkiewicz
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Cezary Statkiewicz
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo
> dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
> costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the
> attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act (Legislative
> Decree June, 30 2003, no.196 - Italy's New Data Protection Code). Any use not
> in accord with its purpose, any disclosure, reproduction, copying,
> distribution, or either dissemination, either whole or partial, is strictly
> forbidden except previous formal approval of the named addressee(s). If you
> are not the intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message that has
> been received in error. The sender does not give any warranty or accept
> liability as the content, accuracy or completeness of sent messages and
> accepts no responsibility  for changes made after they were sent or for other
> risks which arise as a result of e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
