[GeoNode-devel] Question about PR #3103: Add QGIS Server Backend
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Aug 23 00:53:37 PDT 2017
Dear all,
I would like to know if someone of the devs is taking care about this PR.
At the current state it cannot be merged of course. Other than this I see
people keeping pushing commits on that branch and therefore updating the PR
which since a long time is completely misaligned from master branch.
Other issues preventing this PR to be merged are:
- more than 150 files modified; it is almost impossible to do a review of
such huge amount of files
- no connection to issues; each PR should solve a single problem and must
be clear how to reproduce the issue and/or how to test the code. No one can
spend months testing the whole GeoNode functionalities from scratch.
I know that the GeoNode community has no explicit rules yet on the
management or PRs, but usually in order to be merged a PR you should:
- close this huge one.
- split it into several smaller PRs related to specific issues opened on
- whenever is possible attach test cases or at least explain how to test
the code
- manage to keep each PR aligned with the code and Travis to pass the build
I'll be happy to help you merge the PRs as soon as possible after reviewing
them.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170823/5ccbba93/attachment.html>
More information about the geonode-devel mailing list
