[GeoNode-devel] Debugging GeoNode
Alex Goudine agoudine at boundlessgeo.com
Mon Dec 11 16:15:55 PST 2017
Paolo,
I would bring up the services with `docker-compose up`. I will try using
`python manage.py.. ` and see if that makes things easier.
I believe the missing key was to add two lines to the docker-compose.yml
file under Django. I will include this in the related PR, unless someone is
also having the same issue currently in which case I can send them the
snippet to them directly.
Cheers,
Alex.
On Mon, Dec 11, 2017 at 4:07 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Alex
> How do you start the Django process?
> Everything should work properly when running the Django server with
> "python manage.py runserver..."
> cheers
> p
> On Mon, Dec 11, 2017 at 5:58 PM, Alex Goudine <agoudine at boundlessgeo.com>
> wrote:
> > Hello All:
> > I have been trying to debug the GeoNode project using ipdb and pdb for
> > python. However I am getting a 'TerminalInteractiveShell' object has no
> > attribute '_eventloop' error or a BdbQuit exception raised.
> > Has anyone been able to successfully debug latest GeoNode recently? And
> if
> > so, how did you have the project running and what did you use as means
> for a
> > breakpoint?
> > Thanks in advance.
> > Alex Goudine
> > Boundless Geo
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171211/aa3984aa/attachment.html>
More information about the geonode-devel mailing list
