[GeoNode-devel] Integrity error
Simone Dalmasso simone.dalmasso at gmail.com
Wed Dec 13 00:53:37 PST 2017
I suggest you to install the 2.6 on a clean environment. the 2.5 was a dev
version and the 2.6 contains several fixes, probably also this one.
Best regards
2017-12-13 9:48 GMT+01:00 PERDRIEAU Mathieu <
Mathieu.PERDRIEAU at eau-loire-bretagne.fr>:
> Hello,
> On my server, I put Geonode 2.5. It was installed in March 2017.
> But my problem is not in the version, but an error in the Geonode code.
> When I add a new keyword in the documents, it wants to insert it with a
> depth to null. But this value must be not null in the database. And I also
> have the impression that the value of the path is not calculated. Do you
> know where these actions are done? and what modification can I make?
> In addition, do you have the conceptual model of the data?
> Regards
> Mathieu PERDRIEAU
> *De :* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Envoyé :* mercredi 13 décembre 2017 09:02
> *À :* PERDRIEAU Mathieu
> *Cc :* geonode-devel at lists.osgeo.org; geonode-users-bounces at lists.
> osgeo.org
> *Objet :* Re: [GeoNode-devel] Integrity error
> 2.5 is not available. Do you have the 2.6? How did you install it?
> 2017-12-12 13:48 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-
> bretagne.fr>:
> Hi ,
> Escuse me, I made a typing error. My geonode run under version 2.5. It is
> stable?
> The error comes from the hierachialkeywords table, the depth value is
> null. I do not understand why.
> Regards,
> Mathieu PERDRIEAU
> *Envoyé :* mardi 12 décembre 2017 11:07
> *Cc :* geonode-users at lists.osgeo.org
> Hi, geonode 2.9 (master) is considered unstable, the suggestion is to use
> the stable one 2.6 or maybe the 2.7 which is well shaped. We will check
> this for sure before the release.
> Regards
> 2017-12-12 9:20 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-
> bretagne.fr>:
> Hello all,
> Currently I am having a problem with GeoNode. I use geonode 2.9
> My issue is the following :
> When I want to add a new keyword to a document I get the following error:
> ERROR: A NULL value violates the NOT NULL constraint in the depth column
> DETAIL: The failed line contains (71, TestDocumentV2, testdocumentv2_1,,
> null, 0)
> This error only occurs with the documents, did you already meet it? Do you
> have a solution ?
> Thank you
> Mathieu PERDRIEAU
> [image: Description : cid:261c336d-b2fa-429f-b771-cf2edf5f7e75]
> <http://www.facebook.com/pages/Agence-de-leau-Loire-Bretagne/309664692457628>
> [image: Description : cid:image008.png at 01CDF3D6.AF65D5D0]
> <http://twitter.com/LoireBretagne>
> *Agence de l'eau Loire-Bretagne*
> 9 avenue Buffon
> <https://maps.google.com/?q=9+avenue+Buffon&entry=gmail&source=g> - CS
> 36339 - 45063 ORLEANS CEDEX 2
> Tél. : 02 38 51 73 73
> Etablissement public du ministère chargé du développement durable
> *www.eau-loire-bretagne.fr <http://www.eau-loire-bretagne.fr/> Pour un bon
> état des rivières, lacs, nappes et littoral, ensemble, prenons soin de
> l'eau ! *
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> 9 avenue Buffon
> l'eau ! *
> Simone
> 9 avenue Buffon
> l'eau ! *
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171213/89f8b328/attachment.html>
More information about the geonode-devel mailing list
