[GeoNode-devel] Geoserver Layers from 2.4 to 2.6 - permissions
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Dec 19 07:37:57 PST 2017
new versions of GeoServer are able to automatically upgrade the data dir
(make a backup of the old one anyway), however depending on the version of
GeoServer you want to use and version of GeoNode, you will need to tweak a
bit the GeoServer security and regenerate the layer permissions.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Dec 18, 2017 at 9:30 PM, LM Admin <skeenamaps at gmail.com> wrote:
> I understand that the Geoserver data directory is different in 2.6 from
> 2.4.  However, the only problem seems to be that the layers are not visible
> to public users.  Is there a way to replace only the layer permissions on
> the layers imported with the Geonode / Geoserver 2.4 data directory?
> Or is it possible to copy just the layer info from the 2.4 data directory
> into the 2.6 data directory?  I'm not exactly clear on how to do this,
> information referencing layers and styles seems to be in many places.
> LM
> On Fri, Dec 15, 2017 at 3:02 PM, LM Admin <skeenamaps at gmail.com> wrote:
>> Thank you for the suggestions. Should I be using this guide to setup
>> Oauth? http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>> geonode_security/
>> Oauth parameters seem to be set correctly.  ./manage.py sync_geofence did
>> not fix the issue, however.
>> LM
>> On Fri, Dec 15, 2017 at 2:41 PM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> GeoServer data dir is partially different so just copying wouldn’t help.
>>> I think there should be a backup/restore procedure but I haven’t tried it
>>> yet, maybe Paolo and Alessio can help here
>>> Il giorno 15/dic/2017, alle ore 20:58, LM Admin <skeenamaps at gmail.com>
>>> ha scritto:
>>> > Hi all,
>>> > I recently upgraded a client's map portal from Geonode 2.4 to 2.6.  I
>>> copied the db and updated to the 2.6 schema using manage.py --fake-initial,
>>> and updatemaplayerip. I also copied the entire Geoserver data directory.
>>> When logged in as a registered user, maps and layers work fine. However, as
>>> an anonymous user (not logged in), none of the layers render correctly in
>>> Geoserver--instead I get error tiles of class
>>> olTileImage.olImageLoadError.  In Geonode, all of these layers are set to
>>> public.
>>> > However, new layers that I upload display correctly for both
>>> registered and anonymous users. So the permission issue is limited to
>>> layers imported from Geonode 2.4.  Given the change in Geoserver versions,
>>> and the change in authentication, is copying the entire Geoserver data
>>> directory the right thing to do? Or am I missing a step?
>>> > Thank you,
>>> > LM
>>> > _______________________________________________
>>> > geonode-devel mailing list
>>> > geonode-devel at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171219/cf2ede97/attachment-0001.html>
More information about the geonode-devel mailing list
