[GeoNode-devel] Publish WFS Layers with Remote Services app
Jeffrey Johnson jeff at terranodo.io
Fri Feb 10 08:45:58 PST 2017
Just make sure you do some experiments with this kind of datastore in
GeoServer and make sure it performs as you expect before you go
implementing the python side :) It was my experience that cascading
WFS like this was just inefficient with anything but very small
datasets. As I said, the GeoSolutions folks may have some insight into
challenges you might encounter while testing.
On Fri, Feb 10, 2017 at 3:13 AM, Dimitris Karakostis
<karakostis.dimitris at gmail.com> wrote:
> Thanks Jeff. During the coming months I will work on this. Initially I will
> extend the Cascading for WFS as building an indexed WFS wouldn't work with
> our current mapping client.
> I will let you know on progress!
> Cheers
> Dimitris
> On Wed, Feb 8, 2017 at 4:25 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
>> Dimitris,
>> In fact this code (cascaded wfs) should really be removed from GeoNode
>> as it never really worked right. As far as I know, the old WFS Vector
>> Data Store in GeoServer was not working really and I believe this
>> function was removed from gsconfig (would have to look through the
>> history). You might try again with the newer Web Feature Server (NG)
>> datastore type in GeoServer. Check here for the documentation on how
>> to do this in the UI
>> http://docs.geoserver.org/latest/en/user/data/cascaded/wfs.html and
>> http://geoserver.geo-solutions.it/edu/en/adding_data/add_wfscascade.html
>>  You would need to add the necessary bits to gsconfig to configure
>> this via the rest API. Alessio and the Geosolutions folks might be
>> able to help.
>> Note, It may also be possible to add an indexed WFS now and pass it
>> through the proxy such that the new geonode-client can load it. In the
>> past we could not make this work with geoexplorer.
>> Let us know if you make progress. This is a potentially really useful
>> feature.
>> Jeff
>> On Wed, Feb 8, 2017 at 7:17 AM, Dimitris Karakostis
>> > Hello all,
>> > I am checking the current status of the Remote Services app (as of
>> > GeoNode
>> > 2.4) as we want to publish some WMS and WFS Cascaded layers. I have
>> > published some layers as WMS but now I am trying to do the same with WFS
>> > (in
>> > order to be able to download them as shape files).
>> > I understand that there are two ways to register remote services:
>> > 1) as indexed service and
>> > 2) as cascaded service.
>> > Having a closer look at the code I see that WFS is not supported for the
>> > first method (https://goo.gl/ZQY2YU). Checking the
>> > _register_cascaded_layers() function, I see that there is a part
>> > referring
>> > to WFS (https://goo.gl/3v8xZW)
>> > As you can see in the code, it calls a function create_wfslayer() from
>> > gsconfig. I checked the gsconfig latest code and this function is not
>> > available.
>> > Is it possible currently to publish through the Remote Services app WFS
>> > layers? Is there a documentation describing the current status of the
>> > app?
>> > Thanks.
>> > Dimitris
>> > _______________________________________________
>> > geonode-devel mailing list
>> > geonode-devel at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
Jeffrey Johnson
Managing Principal
p: 17602089488
e: jeff at terranodo.io
w: terranodo.io
More information about the geonode-devel mailing list
