[GeoNode-devel] Geonode 2.4 on Ubuntu 16.04 - unmet dependencies
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jan 5 05:08:32 PST 2017
Hi Jonathan,
We have updated the ansible role on ansible galaxy to work with Ubuntu
16.04 Xenial.
I hope that helps too.
Best,
Angelos
On 11/18/2016 02:57 AM, j.doig at unsw.edu.au wrote:
> Hi Jeffrey et al
> I’ve published my simple Ansible role for Geonode 2.4 installation on Ubuntu 16.04:
> https://github.com/UNSW-CFRC/geonode_install
> Note the disclaimers in the ReadMe ☺
> Jonathan
> From: Jeffrey Johnson [mailto:ortelius at gmail.com]
> Sent: Monday, 14 November 2016 8:24 PM
> To: Jonathan Doig
> Cc: Simone Dalmasso; geonode-devel at lists.osgeo.org
> Subject: Re: [GeoNode-devel] Geonode 2.4 on Ubuntu 16.04 - unmet dependencies
> Thanks Jonathan. I'll look at your role and see what I can do to merge it with the main one when I'm back from holidays.
> On Monday, November 14, 2016, Jonathan Doig <j.doig at unsw.edu.au<mailto:j.doig at unsw.edu.au>> wrote:
> Thanks guys
> I had a look at your role for 14.04 – it’s much more robust than my fledgling effort, so I won’t be able to offer a comparable 16.04 role. Still when someone does a 16.04 version it might be worth having a look over mine to see what I had to fix, or other config items I chose to add that you might want to consider.
> I’ll have to break it out of its existing repo before I share though. I’ll let you know when done.
> Cheers
> Jonathan
> From: Jeffrey Johnson [mailto:ortelius at gmail.com<javascript:_e(%7B%7D,'cvml','ortelius at gmail.com');>]
> Sent: Friday, 11 November 2016 10:55 PM
> To: Simone Dalmasso
> Cc: Jonathan Doig; geonode-devel at lists.osgeo.org<javascript:_e(%7B%7D,'cvml','geonode-devel at lists.osgeo.org');>
> +1 I can help when I'm back from holidays.
> On Friday, November 11, 2016, Simone Dalmasso <simone.dalmasso at gmail.com<javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> wrote:
> Thanks Jonathan,
> we have a role for Ubuntu 14.04 https://github.com/GeoNode/ansible-geonode, I think it would be good to have a branch for 16 too. Right @jj0hns0n?
> 2016-11-10 23:51 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au<mailto:j.doig at unsw.edu.au>>:
> Thanks Simone
> I followed those instructions – with a few changes – and managed to get Geonode 2.4 installed on Ubuntu 16.04, thanks.
> I’ve created Ansible playbooks for the whole thing, may be able to share these if helpful. They’re pretty basic, no error-checking, but they work for me.
> Jonathan
> From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Sent: Thursday, 3 November 2016 5:33 PM
> To: Jonathan Doig
> Cc: geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
> Hi,
> not sure that's the issue because the only place geonode 2.5 is available is in the testing ppa moreover the error is that geonode depends on django <=1.7 but the 1.8 is to be installed and I think is because the 1.6 might not be available for xenial https://launchpad.net/ubuntu/+source/python-django.
> I would suggest you to go for the manual installation under a virtualenv, the doc is for the 2.4 but the process is very similar http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> hope this helps
> 2016-11-03 0:01 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au<mailto:j.doig at unsw.edu.au>>:
> Hi devs
> No reply on geonode-users, so I’m trying here.
> Thanks
> Jonathan
> From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On Behalf Of Jonathan Doig
> Sent: Wednesday, 2 November 2016 5:05 PM
> To: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
> Subject: [GeoNode-users] Geonode 2.4 on Ubuntu 16.04
> Hi
> I’m trying to install Geonode 2.4 on Ubuntu 16.04, being new to both.
> I’m stepping through the OSGeoLive install_geonode.sh script following this advice from Angelos Tzotsos on Aug 18:
>>   GeoNode 2.4 works fine on Xenial.
>>   The Debian packaging has been updated accordingly.
>>   Please check the OSGeoLive install script to find out how to install:
>>   https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
> However line 50:
> apt-get --assume-yes install python-geonode libapache2-mod-wsgi curl
> Is giving trouble:
> The following packages have unmet dependencies:
> python-geonode : Depends: python-django (<= 1.7) but 1.8.7-1ubuntu5.2 is to be installed
>                    Recommends: transifex-client but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> I think it’s because python-geonode is v2.5.5 which uses django 1.8, where I want v2.4 which needs django 1.6.
> I tried specifying a geonode version: --target_release ‘2.4*’ or /release or /stable but nothing was found.
> Advice please.
> Thanks
> Jonathan Doig
> Software Engineer – Spatial Systems
> City Futures Research Centre
> UNSW Built Environment
> cityfutures.net.au<http://cityfutures.be.unsw.edu.au/>
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> Simone
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170105/98800e7d/attachment.html>
More information about the geonode-devel mailing list
