[GeoNode-devel] Issue building GeoServer-GeoNode-ext due to missing geogig artifacts
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jan 9 03:31:51 PST 2017
Hi guys,
can someone help with this issue?
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 54.889 s
[INFO] Finished at: 2017-01-09T11:45:35+00:00
[INFO] Final Memory: 28M/67M
[INFO] ------------------------------------------------------------------------[ERROR]
Failed to execute goal on project geonode-geoserver-ext: Could not
resolve dependencies for project
org.opengeo:geonode-geoserver-ext:jar:2.9-SNAPSHOT: The following
artifacts could not be resolved:
org.locationtech.geogig:geogig-cli:jar:1.1-SNAPSHOT,
org.locationtech.geogig:geogig-geotools:jar:1.1-SNAPSHOT,
org.locationtech.geogig:geogig-datastore:jar:1.1-SNAPSHOT,
org.locationtech.geogig:geogig-web-api:jar:1.1-SNAPSHOT,
org.locationtech.geogig:geogig-postgres:jar:1.1-SNAPSHOT: Could not
find artifact org.locationtech.geogig:geogig-cli:jar:1.1-SNAPSHOT in
geosolutions (http://maven.geo-solutions.it/) -> [Help 1][ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with
the -e switch.[ERROR] Re-run Maven using the -X switch to enable full
debug logging.[ERROR] [ERROR] For more information about the errors
and possible solutions, please read the following articles:[ERROR]
[Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException[JENKINS]
Archiving /disk/jenkins/workspace/geoserver-geonode-dev-oauth2/pom.xml
to org.opengeo/geonode-geoserver-ext/2.9-SNAPSHOT/geonode-geoserver-ext-2.9-SNAPSHOT.pom
channel stopped
Finished: FAILURE
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170109/8a2e134e/attachment-0001.html>
More information about the geonode-devel mailing list
