[GeoNode-devel] coveralls tollerance
Jeffrey Johnson ortelius at gmail.com
Wed Jan 18 07:27:53 PST 2017
I'm not sure how to configure the tolerance, but it is ok to just
ignore these failures and merge. It is not setup to block PRs like
this (as Jenkins is when the build fails).
On Wed, Jan 18, 2017 at 7:24 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi devs
> I see that coveralls makes build fails if some code line is added
> without adding any tests.
> While I believe this is a good practice, it would be great if we could
> have some tolerance: for example adding just 1-2 code lines without
> tests should not make the build fail. I wonder if this is possible
> my 2 cents
> cheers
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
