[GeoNode-devel] [GeoNode-users] GeoNode - PyCSW integration issues
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jul 26 03:14:26 PDT 2017
Dear Cor,
thanks for your reply. You are right, the Dublin Core was just an example.
ISO 19115 output form PyCSW has same issues though.
Problem is that mapping between GeoNode and PyCSW is currently missing some
important information.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Jul 26, 2017 at 12:11 PM, Cor Melse <cor.melse at gmail.com> wrote:
> Dear Alessio,
> One should never use the Dublin Core output from a CSW, but instead use
> the OGC- CWS ISO19139 output!
> There the right information for geo datasets (services) is provided.
> Following the notes by Stephen Richard is therefore the only right thing
> to do.
> as an alternative for pyCSW Geonetwork is also a great tool to use (and
> OSS)
> Cheers, Cor
> 2017-07-26 11:10 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Dear all,
>> I want to highlight some important issues about the current integration
>> between GeoNode and PyCSW.
>> Other than a non-trivial security issue (basically the CSW exposes
>> metadata for all Layers no matter if they are accessible or not by the
>> user), one more, I would say, big issue is that currently is not possible
>> to recognize the Layer "real name" from the metadata documents.
>> Let me provide an example. Here below a snippet of a DublinCore XML
>> produced by PyCSW
>> <csw:Record>
>>     <dc:identifier>941a8d7e-7159-11e7-b283-002215079c40</dc:identifier>
>>     <dc:title>san_andres_y_providencia_highway</dc:title>
>>     <dc:type>dataset</dc:type>
>>     <dc:subject/>
>>     <dct:references scheme="WWW:DOWNLOAD-1.0-http--download">
>> http://localhost:8080/geoserver/wms?request=GetLe
>> gendGraphic&format=image/png&WIDTH=20&HEIGHT=
>> 20&LAYER=geonode:san_andres_y_providencia_highway&
>> amp;legend_options=fontAntiAliasing:true;fontSize:12;forceLabels:on</dct:
>> references>
>>     <dct:references scheme="OGC:WMS">http://localh
>> ost:8080/geoserver/geonode/wms</dct:references>
>>     <dct:references scheme="OGC:WFS">http://localh
>> ost:8080/geoserver/geonode/wfs</dct:references>
>> (full XML here https://pastebin.com/Wu0vm79B)
>> Seems to be good right? *Wrong!* There some important things missing
>> here:
>> 1. It is not possible to recognize the layer name at all; The element
>> "title" is mapped to the resource title, meaning that whenever I change it
>> on the metadata into a human readable fashion, I lose the layer name forever
>> 2. Layer qualified name is missing; if the name had a namespace, like on
>> GeoServer, it is not possible to know which is at all
>> 3. WMS and WFS links cannot be used at all, since the layer name cannot
>> be retrieved anywhere
>> *Proposal*
>> Following the notes written by Stephen Richard here https://github.co
>> m/geopython/pycsw/wiki/Geonode-notes
>> the proposal here would be to add more references
>> OGC:WMS-1.1.1-http-get-capabilities
>> OGC:WMS-1.3.0-http-get-capabilities
>> OGC:WMS-1.1.1-http-get-map
>> OGC:WMS-1.3.0-http-get-map
>> OGC:WMS-1.1.1-http-get-featureinfo
>> OGC:WMS-1.3.0-http-get-featureinfo
>> OGC:WFS-1.0.0-http-get-capabilities
>> OGC:WFS-1.0.0-http-describe-feature
>> OGC:WFS-1.0.0-http-get-feature
>> OGC:WCS-1.1.0-http-get-capabilities
>> OGC:WCS-1.1.0-http-describe-coverage
>> OGC:WCS-1.1.0-http-get-coverage
>> in order to let CSW being able to send correct links to the clients.
>> If there are no objections, I will create a PR accordingly related to the
>> following ISSUE
>> https://github.com/GeoNode/geonode/issues/2720#issuecomment-262829872
>> Please comment on this.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170726/0e2fc0cf/attachment-0001.html>
More information about the geonode-devel mailing list
