[GeoNode-devel] Windows installer as 64 bit
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Mar 2 09:48:36 PST 2017
GNU GPL
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Mar 2, 2017 at 6:46 PM, Jaco du Plooy <jacoduplooy1969 at gmail.com>
wrote:
> Sorry, what licence are you using?
> On Thu, Mar 2, 2017 at 7:43 PM, Jaco du Plooy <jacoduplooy1969 at gmail.com>
> wrote:
>> Thanks.
>> Final question
>> Could the newest gdal from gisinternals be used?
>> On Thu, Mar 2, 2017 at 7:38 PM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> I usually test it on 64 bit systems.
>>> Python and virtual env are self-contained so there shouldn't be issues.
>>> Updating to 64bit would mean to create another version with 64-bit
>>> installers of contained packages.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Thu, Mar 2, 2017 at 6:33 PM, Jaco du Plooy <jacoduplooy1969 at gmail.com
>>> > wrote:
>>>> Hi Alessio
>>>> I was wondering if anyone has tried before?  Any problems that you can
>>>> forsee?
>>>> Any specific requirements?
>>>> Pieter
>>>> On Thu, Mar 2, 2017 at 7:26 PM, Alessio Fabiani <
>>>>> Sure.
>>>>> It is possible to have it on a separate branch? So we can have 2
>>>>> installers 32 bit and 64 bit in the future
>>>>> Thanks,
>>>>> Alessio.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Thu, Mar 2, 2017 at 6:18 PM, Jaco du Plooy <
>>>>> jacoduplooy1969 at gmail.com> wrote:
>>>>>> Hi guys
>>>>>> I was wondering if there are any problems having the installer as 64
>>>>>> bit for Windows? I want to take a hack at it, to see if it is feasible.
>>>>>> Pieter
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170302/56e995aa/attachment-0001.html>
More information about the geonode-devel mailing list
