[GeoNode-devel] Geonode notifications (old and new)
Simone Dalmasso simone.dalmasso at gmail.com
Fri May 5 10:59:55 PDT 2017
We didn't take a look at the original repos for a while... if they are
updated we will be more than happy to used them and discard the geonode
forks.
Thanks for the work
2017-05-05 18:49 GMT+02:00 Cezary Statkiewicz <
cezary.statkiewicz at geo-solutions.it>:
> On Friday, May 5, 2017 3:24:56 PM CEST Simone Dalmasso wrote:
> > Hi Cezary,
>  Hi!
> > thanks for the good summary of issues, this will be useful.
> > As you said the notification app will be completely rewritten soon and I
> > think that your suggestions are precious.
> > Have you tried the 2.6.x branch too?
>  No, I haven't. I'm working on 2.7 actually, so, after a second thought,
> pubsub is not my main concern here.
> > To answer your questions, the reason of forking the apps was for two
> > reasons:
> > - we needed to change few small things to make them compatible with
> geonode
> > like [1]
>  Right. But similar change was introduced some time later to pinax version
> [1]
> > - we needed to push them to pypi and launchpad as packages.
> > and some of them didn't seem maintained anymore when we did it.
> > They are all used by the geonode ubuntu installer and python installer.
>  Original app is also on on pypi [2]. It also supports current Django
> versions. I believe deb packages can be created from it as well (I couldn't
> locate any deb-packaging specific code in notification app, so I assume
> you're
> using pybuild or something similar).
>  I've checked also geonode-user-accounts. While it's missing geonode-
> notification dependency in setup.py, it's using it for sending registration
> moderation emails [3]. I believe this could be decoupled from geonode-user-
> accounts, using signal handler in geonode [4]. Do you think it is possible
> to
> synchronize with django-user-accounts or port geonode-specific changes
> (like
> registration moderation) to upstream?
>  I'm making an attempt to replace notification app with original pinax
> version, as it's better maintained. Part of it would be to use
> NOTIFICATIONS_MODULE setting, which would name notification app
> (notification
> or pinax.notifications). Also, integration code is repeated in management/
> __init__.py files in several places. I'm rewriting this to have single
> point
> of installation of notification types (with respect to INSTALLED_APPS).
>  BR,
>  CS
> [1] https://github.com/pinax/pinax-notifications/pull/34/files
> [2] https://github.com/GeoNode/geonode-user-accounts/blob/master/account/
> views.py#L136
> [3] https://pypi.python.org/pypi/pinax-notifications/
> [4] https://github.com/GeoNode/geonode-user-accounts/blob/master/account/
> signals.py#L6
> > [1]
> > https://github.com/GeoNode/geonode-notification/commit/
> 41b1b9acbb4ba9f621c1a
> > dcdceef692144959b51
> > 2017-05-05 14:35 GMT+02:00 Cezary Statkiewicz <
> > >  Hi,
> > >  I wanted to use geonode-notification app [1], but found it won't work
> > > with GeoNode master branch. I'd like to list problems I've bumped into
> and
> > > establish if my understanding is correct:
> > >  * app code itself seems to be a copy of old version of
> > > pinax-notifications (renamed from django-notification) [2]. Besides
> > > renaming to geonode-notification, I can't tell if there are any
> functional
> > > differences between those two. Core functionality code seems to be not
> > > updated since then.
> > >  * settings template (notification/notice_settings.html) is present
> both
> > > in GeoNode [3] and in app [4], and are almost the same (except for
> button
> > > element in the bottom). This is clear code duplication.
> > >  * settings template inherits from notification/base.html, which
> inherits
> > > from account/base.html template, which is not present anywhere (not in
> > > GeoNode, not in geonode-notification/pinax-notifications). Some clue
> > > would be dependency on django-user-account in pinax app (which was also
> > > copied to geonode-user-accounts app in the past). So, settings view
> won't
> > > work, unless inheritance base is changed to existing template.
> > >  * integration code in GeoNode 2.6 ([5] for example) won't work and
> won't
> > > populate Notification types, because signals binding has different
> > > signature. Proper signal binding involves AppConfig instance, which was
> > > introduced in Django 1.7. Working integration code is described in
> updated
> > > pinax app (see below for similar problem in master branch).
> > >  * Current dev version of GeoNode introduced new notification
> dispatching
> > > mechanism [6], which uses notification app as a consumer (not directly,
> > > but
> > > mechanism is used in callbacks [13]). In GNIP PR, there are traces of
> > > refactoring notification app integration: [7], [8]. Code from [7] uses
> > > deprecated post_syncdb signal [9][10]. Instead it should use proper
> > > AppConfig or, as provided by Pinax app docs [11]. I'm not sure why
> part of
> > > NoticeTypes are created in signal handler, while other are created with
> > > script.
> > >  * Some work for making this mechanism optional (or co-working with
> > > notification app) was started [12], but that PR seems to be in early
> > > stages.>
> > > My concerns and questions here are as follows:
> > >  1. Why geonode-notification app was created? It doesn't provide any
> > > additional functionality over original pinax apps.
> > >  2. It seems geonode-notificaiton app is not maintained at all
> > > (geonode-user-account app as well). Most of code base is 3-4 years old,
> > > written for pre-1.7 Django versions. There were few commits to update
> code
> > > with migrations, but that was whole contribution to this app. There
> are no
> > > issues (active nor solved), no pull requests. Is anyone using this app
> at
> > > all?
> > >  3. Wouldn't it be better to advice use of pinax apps directly here?
> As I
> > > wrote before, geonode-notification app for doesn't provide any new
> > > functionality.
> > >  References:
> > > [1] https://github.com/GeoNode/geonode-notification
> > > [2] https://github.com/pinax/pinax-notifications
> > > [3] https://github.com/GeoNode/geonode/blob/2.6.x/geonode/
> > > templates/notification/notice_settings.html
> > > [4] https://github.com/GeoNode/geonode-notification/blob/
> > > master/notification/templates/notification/notice_settings.html
> > > [5] https://github.com/GeoNode/geonode/blob/
> 5bd1bfa794d92bb47b2e113f22a1fe
> > > 1ed1257ff4/geonode/layers/management/__init__.py#L55
> > > [6] https://github.com/GeoNode/geonode/issues/2889
> > > [7] https://github.com/GeoNode/geonode/pull/2911/files#diff-> >
> 3efadb31867c7c011d76f234bf4f3cf9R27
> > > [8] https://github.com/GeoNode/geonode/pull/2911/files#diff-> >
> 2e37d4a8264969d920999e14976b60a1R129
> > > [9] https://github.com/GeoNode/geonode/pull/2911/files#diff-> >
> 3efadb31867c7c011d76f234bf4f3cf9R35
> > > [10] https://docs.djangoproject.com/en/1.8/ref/signals/#post-syncdb
> > > [11] https://github.com/pinax/pinax-notifications/blob/
> > > master/docs/usage.md#creating-notice-types
> > > [12] https://github.com/GeoNode/geonode/pull/2995
> > > [13] https://github.com/GeoNode/geonode/pull/2911/files#diff-> >
> 65e028487582782a9d3e44fb6a9884bcL165
> Regards,
> Cezary Statkiewicz
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Cezary Statkiewicz
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo
> dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in
> parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse,
> costituisce comportamento contrario ai principi dettati dal D.Lgs.
> 196/2003.
> The information in this message and/or attachments, is intended solely for
> the
> attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative
> Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use
> not
> in accord with its purpose, any disclosure, reproduction, copying,
> distribution, or either dissemination, either whole or partial, is strictly
> forbidden except previous formal approval of the named addressee(s). If you
> are not the intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message that
> has
> been received in error. The sender does not give any warranty or accept
> liability as the content, accuracy or completeness of sent messages and
> accepts no responsibility  for changes made after they were sent or for
> other
> risks which arise as a result of e-mail transmission, viruses, etc.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170505/c4ecedff/attachment-0001.html>
More information about the geonode-devel mailing list
