[GeoNode-devel] geonode 2.7.x vs master branch
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri May 12 00:59:41 PDT 2017
Hi Simone,
yes I'm monitoring the situation. Currently I'm trying to keep master and
2.7.x aligned as much as possible.
Now that the PUBSUB stuff has been fixed, after having tested it, my
propose is to return to normal situation.
Unless other comments I would proceed like this:
1. Forward port 2.7.x improvements to master branch (now working)
2. Let the 2.7.x become an aligned branch of master
3. Move master to 2.8.x
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, May 12, 2017 at 9:49 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Dears,
> I noticed a lot of great contributions going on the repo lately, this is
> great. I noticed that some of them are addressed to master and some on the
> 2.7.x branch.
> We used to use the numbered branches to freeze master just before the
> release and do there only small fixes but most of the development is always
> been on master.
> I think we could end up in a very difficult to manage situation if we
> split the commits between 2 as they will be soon very misaligned.
> This is just a reminder :) before things get messy. There are for sure
> reasons why lots of stuff is going to 2.7.x but just let's keep in mind to
> keep 2.7.x and master aligned. Same applies to the small fixes on 2.6.x
> that have to be ported on master, but that is easy.
> Ciao!
> Simone
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170512/df56c6d0/attachment.html>
More information about the geonode-devel mailing list
