[GeoNode-devel] geonode 2.7.x vs master branch
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri May 12 03:17:13 PDT 2017
Hi all,
Actually, as Simone noted, the unstable releases (2.5.x) happened from
master in the past, and I agree that this should keep happening.
Since the pubsub stuff is now fixed, what is holding us from having
2.7.x merged back to master and deleted? The notification work? If yes,
I propose we rename current master to notification_branch (since it is
already linearly behind 2.7.4) and rename 2.7.x to master until the new
notification system can be optional.
Thoughts?
Angelos
On 05/12/2017 10:59 AM, Alessio Fabiani wrote:
> Hi Simone,
> yes I'm monitoring the situation. Currently I'm trying to keep master and
> 2.7.x aligned as much as possible.
> Now that the PUBSUB stuff has been fixed, after having tested it, my
> propose is to return to normal situation.
> Unless other comments I would proceed like this:
> 1. Forward port 2.7.x improvements to master branch (now working)
> 2. Let the 2.7.x become an aligned branch of master
> 3. Move master to 2.8.x
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, May 12, 2017 at 9:49 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
>> Dears,
>> I noticed a lot of great contributions going on the repo lately, this is
>> great. I noticed that some of them are addressed to master and some on the
>> 2.7.x branch.
>> We used to use the numbered branches to freeze master just before the
>> release and do there only small fixes but most of the development is always
>> been on master.
>> I think we could end up in a very difficult to manage situation if we
>> split the commits between 2 as they will be soon very misaligned.
>> This is just a reminder :) before things get messy. There are for sure
>> reasons why lots of stuff is going to 2.7.x but just let's keep in mind to
>> keep 2.7.x and master aligned. Same applies to the small fixes on 2.6.x
>> that have to be ported on master, but that is easy.
>> Ciao!
>> Simone
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170512/42d29928/attachment.html>
More information about the geonode-devel mailing list
