[GeoNode-devel] geonode 2.7.x vs master branch
Simone Dalmasso simone.dalmasso at gmail.com
Fri May 12 03:23:08 PDT 2017
I agree Angelos,
+1
2017-05-12 12:18 GMT+02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> s/2.7.4/2.7.x/g
> On 05/12/2017 01:17 PM, Angelos Tzotsos wrote:
>> Hi all,
>> Actually, as Simone noted, the unstable releases (2.5.x) happened from
>> master in the past, and I agree that this should keep happening.
>> Since the pubsub stuff is now fixed, what is holding us from having 2.7.x
>> merged back to master and deleted? The notification work? If yes, I propose
>> we rename current master to notification_branch (since it is already
>> linearly behind 2.7.4) and rename 2.7.x to master until the new
>> notification system can be optional.
>> Thoughts?
>> Angelos
>> On 05/12/2017 10:59 AM, Alessio Fabiani wrote:
>>> Hi Simone,
>>> yes I'm monitoring the situation. Currently I'm trying to keep master and
>>> 2.7.x aligned as much as possible.
>>> Now that the PUBSUB stuff has been fixed, after having tested it, my
>>> propose is to return to normal situation.
>>> Unless other comments I would proceed like this:
>>> 1. Forward port 2.7.x improvements to master branch (now working)
>>> 2. Let the 2.7.x become an aligned branch of master
>>> 3. Move master to 2.8.x
>>> Best Regards,
>>> Alessio Fabiani.
>>> GeoServer Professional Services from the experts!
>>> Visit http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> github <https://github.com/afabiani?tab=overview>
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for
>>> the attention and use of the named addressee(s) and may be confidential
>>> or
>>> proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure,
>>> reproduction,
>>> copying, distribution, or either dissemination, either whole or partial,
>>> is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy
>>> or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Fri, May 12, 2017 at 9:49 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com>
>>> wrote:
>>> Dears,
>>>> I noticed a lot of great contributions going on the repo lately, this is
>>>> great. I noticed that some of them are addressed to master and some on
>>>> the
>>>> 2.7.x branch.
>>>> We used to use the numbered branches to freeze master just before the
>>>> release and do there only small fixes but most of the development is
>>>> always
>>>> been on master.
>>>> I think we could end up in a very difficult to manage situation if we
>>>> split the commits between 2 as they will be soon very misaligned.
>>>> This is just a reminder :) before things get messy. There are for sure
>>>> reasons why lots of stuff is going to 2.7.x but just let's keep in mind
>>>> to
>>>> keep 2.7.x and master aligned. Same applies to the small fixes on 2.6.x
>>>> that have to be ported on master, but that is easy.
>>>> Ciao!
>>>> Simone
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Angelos Tzotsos, PhD
> Charter Member
> Open Source Geospatial Foundation
> http://users.ntua.gr/tzotsos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170512/9c8da322/attachment-0001.html>
More information about the geonode-devel mailing list
