[GeoNode-devel] GeoNode monitoring
Paolo Corti pcorti at gmail.com
Thu Oct 12 07:03:49 PDT 2017
You are right. I may have open a different branch requirements file
when checking
sorry about it
great work!
cheers
p
On Thu, Oct 5, 2017 at 6:08 AM, Cezary Statkiewicz
<cezary.statkiewicz at geo-solutions.it> wrote:
> From: "Paolo Corti" pcorti at gmail.com
> To: "Cezary Statkiewicz" cezary.statkiewicz at geo-solutions.it
> Cc: "geonode-devel" geonode-devel at lists.osgeo.org
> Date: Wed, 4 Oct 2017 11:52:35 -0400
> Subject: Re: [GeoNode-devel] GeoNode monitoring
>  Hello,
>> I gave another try right now. I run collect_metrics, and now I see an
>> error when accessing the monitoring page:
>>     return self.cursor.execute(sql, params)
>>   File "/home/vagrant/env_gn_master/local/lib/python2.7/site-packages/django/db/utils.py",
>> line 98, in __exit__
>>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>   File "/home/vagrant/env_gn_master/local/lib/python2.7/site-packages/django/db/backends/utils.py",
>> line 64, in execute
>>   File "/home/vagrant/env_gn_master/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py",
>> line 318, in execute
>>     return Database.Cursor.execute(self, query, params)
>> OperationalError: near "%": syntax error
>  Could you add an issue for this problem? It looks like sqlite-specific problem, but I'll have to debug.
>> By the way, I see that with latest pushes there is some more
>> requirements you need to add in requirements.txt and setup.py:
>> user_agents
>> xmljson
>> psutil
> They should be there already:
> https://github.com/geosolutions-it/geonode/blob/monitoring/requirements.txt#L122-L124
> https://github.com/geosolutions-it/geonode/blob/monitoring/setup.py#L198-L200
>  Best Regards,
>  Cezary Statkiewicz
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Cezary Statkiewicz
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
