[GeoNode-devel] Customize GeoNode
Tom Pyatt tom.pyatt.nz at gmail.com
Sun Oct 15 18:32:41 PDT 2017
I have attempted the instructions you referenced and they are not resulting
in a workable GeoNode. Perhaps the documentation has not been fully updated
to work with the GeoNode 2.6.3 version. There seem to be a few variations of
those docs and all have failed for me when attempting to use GeoNode 2.6.3.
After a bit of trial and error I was successful using the more simplified
approach outlined on the geonode-project page (
https://github.com/GeoNode/geonode-project/ ).
My steps were this.
Install geonode 2.6.3 with:
$ sudo add-apt-repository ppa:geonode/stable
$ sudo apt-get update
$ sudo apt-get install geonode
Create a new template based on the geonode example project.:
$ django-admin startproject my_geonode
--template=https://github.com/GeoNode/geonode-project/archive/2.6.zip
-epy,rst
$ sudo pip install -e my_geonode
(Ignored the local_settings.py usage as it is not required)
$ cp /path/to/my_geonode/my_geonode/wsgi.py /var/www/geonode/wsgi/wsgi.py
Edit the file /etc/apache2/sites-available/geonode as per instructions
$ sudo service apache2 restart
Edit the templates in my_geonode/templates
$ python manage.py collectstatic
Tom
From: Francesco Bartoli [mailto:xbartolone at gmail.com]
Sent: Friday, October 13, 2017 7:39 PM
To: Tom Pyatt <tom.pyatt.nz at gmail.com>
Cc: geonode-devel at lists.osgeo.org
Subject: Re: [GeoNode-devel] Customize GeoNode
The workshop done at last foss4g probably can help you as it covers
customization extensively. The right place in the documentation is
http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/index.h
tml?#customize-the-look-and-feel though.
Hope this helps
Francesco
Il giorno 13/ott/2017, alle ore 06:26, Tom Pyatt <tom.pyatt.nz at gmail.com
<mailto:tom.pyatt.nz at gmail.com> > ha scritto:
I am new to this list so these questions may have been asked already.
I can install GeoNode 2.6.3 using the instructions given in the Developers
Workshop, although there are a few errors in the instructions. I then wish
to customize the look. The instructions in the workshop do not seem to work
and are very different to the instructions on the geonode-project page. It's
all a bit confusing.
The workshop manual contains this "disable_local_repo.sh". This does not
exist and there seems to be no reference to it anywhere else.
But before I start posting all the errors I get I was hoping there might a
working process that I have not seen yet.
Tom
geonode-devel mailing list
geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171016/c04765ff/attachment.html>
More information about the geonode-devel mailing list
