[GeoNode-devel] Customize GeoNode
Francesco Bartoli xbartolone at gmail.com
Mon Oct 16 00:48:34 PDT 2017
Why you are doing this step?
$ cp /path/to/my_geonode/my_geonode/wsgi.py /var/www/geonode/wsgi/wsgi.py
Where did you find it in the documentation?
Il giorno 16/ott/2017, alle ore 03:32, Tom Pyatt <tom.pyatt.nz at gmail.com> ha scritto:
> I have attempted the instructions you referenced and they are not resulting in a workable GeoNode. Perhaps the documentation has not been fully updated to work with the GeoNode 2.6.3 version. There seem to be a few variations of those docs and all have failed for me when attempting to use GeoNode 2.6.3.
> After a bit of trial and error I was successful using the more simplified approach outlined on the geonode-project page ( https://github.com/GeoNode/geonode-project/ ).
> My steps were this.
> Install geonode 2.6.3 with:
> $ sudo add-apt-repository ppa:geonode/stable
> $ sudo apt-get update
> $ sudo apt-get install geonode
> Create a new template based on the geonode example project.:
> $ django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/2.6.zip -epy,rst
> $ sudo pip install -e my_geonode
> (Ignored the local_settings.py usage as it is not required)
> Edit the file /etc/apache2/sites-available/geonode as per instructions
> $ sudo service apache2 restart
> Edit the templates in my_geonode/templates
> $ python manage.py collectstatic
> Tom
> From: Francesco Bartoli [mailto:xbartolone at gmail.com]
> Sent: Friday, October 13, 2017 7:39 PM
> To: Tom Pyatt <tom.pyatt.nz at gmail.com>
> Cc: geonode-devel at lists.osgeo.org
> Subject: Re: [GeoNode-devel] Customize GeoNode
> The workshop done at last foss4g probably can help you as it covers customization extensively. The right place in the documentation is http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/index.html?#customize-the-look-and-feel though.
> Hope this helps
> Francesco
> Il giorno 13/ott/2017, alle ore 06:26, Tom Pyatt <tom.pyatt.nz at gmail.com> ha scritto:
> I am new to this list so these questions may have been asked already.
> I can install GeoNode 2.6.3 using the instructions given in the Developers Workshop, although there are a few errors in the instructions. I then wish to customize the look. The instructions in the workshop do not seem to work and are very different to the instructions on the geonode-project page. It’s all a bit confusing.
> The workshop manual contains this “disable_local_repo.sh”. This does not exist and there seems to be no reference to it anywhere else.
> But before I start posting all the errors I get I was hoping there might a working process that I have not seen yet.
> Tom
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171016/750a5be5/attachment.html>
More information about the geonode-devel mailing list
