[GeoNode-devel] [Geoserver-devel] GeoGig Exception with GeoServer 2.12+
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Oct 18 00:35:59 PDT 2017
Hi Erik,
thanks to you for your effort. Will test and report back the results.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Oct 17, 2017 at 10:49 PM, Erik Merkle <emerkle at boundlessgeo.com>
wrote:
> Alessio,
> I just merged what "should" fix the issue. I wasn't able to reproduce it
> locally. I assume there needs to be some other REST interaction outside of
> GeoGig calls.
> The PRs are merged here:
> master - https://github.com/geoserver/geoserver/pull/2603
> 2.12.x - https://github.com/geoserver/geoserver/pull/26034
> ​The fix should at least prevent the NPE, and generate a debug log that
> might give more information if it doesn't work as expected.​
> ​Thanks again for your patience,
> Erik Merkle
> Software Engineer | Boundless <http://boundlessgeo.com/>
> <http://d32wfbeasdaw38.cloudfront.net/img/Boundless_Logo.png>
> On Tue, Oct 17, 2017 at 10:27 AM, Erik Merkle <emerkle at boundlessgeo.com>
> wrote:
>> Thanks Alessio. I'll get a fix out ASAP
>> Erik Merkle
>> On Tue, Oct 17, 2017 at 10:26 AM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Hi Erik,
>>> sure and thanks for your time.
>>> Currently this is happening when running the war compiled with this
>>> modules
>>> https://github.com/GeoNode/geoserver-geonode-ext
>>> http://build.geonode.org/geoserver/latest/geoserver-2.12.x.war
>>> http://build.geonode.org/geoserver/latest/data-2.12.x.zip
>>> Is it possible that could be an issue when including the monitoring
>>> plugin also?
>>> P.S.: in order to start that WAR you have to provide
>>> "GEOSERVER_DATA_DIR" and "geofence.dir" JVM OPTS
>>> Regards,
>>> Alessio Fabiani
>>> http://goo.gl/it488V for more information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Tue, Oct 17, 2017 at 5:21 PM, Erik Merkle <emerkle at boundlessgeo.com>
>>> wrote:
>>>> Alessio,
>>>> Can you give me any more details about your environment/setup when you
>>>> see this? I can't reproduce it with the community GeoServer 2.12-beta and
>>>> the plugin. I think I can fix it, but I'd like to be able to reproduce it
>>>> to be sure.
>>>> Many thanks again,
>>>> Erik Merkle
>>>> On Tue, Oct 17, 2017 at 9:36 AM, Alessio Fabiani <
>>>>> Hi Erik,
>>>>> unfortunately is still doesn't work fine
>>>>> Stacktrace here:
>>>>> https://bpaste.net/show/09e2f5b6c0d8
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> On Tue, Oct 17, 2017 at 9:44 AM, Alessio Fabiani <
>>>>>> Thanks Erik,
>>>>>> will make a test asap.
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Tue, Oct 17, 2017 at 12:54 AM, Erik Merkle <
>>>>>> emerkle at boundlessgeo.com> wrote:
>>>>>>> Alessio,
>>>>>>> Thanks for letting me know. I hadn't come across this in testing
>>>>>>> myself, but theses 2 merged PRs should address the issue:
>>>>>>> (master) - https://github.com/geoserver/geoserver/pull/2600
>>>>>>> (2.12.x) - https://github.com/geoserver/geoserver/pull/2601
>>>>>>> ​Let me know if you still have issues with the plugin for GeoGig,
>>>>>>> Erik Merkle
>>>>>>> On Fri, Oct 13, 2017 at 12:16 PM, Alessio Fabiani <
>>>>>>>> Sorry for cross-posting.
>>>>>>>> Just wanted to highlight that currently trying to use GeoGig
>>>>>>>> extension on GeoServer 2.12+ throws the following exception
>>>>>>>> 13 ott 19:13:16 ERROR [geoserver.rest] -
>>>>>>>> java.lang.NullPointerException
>>>>>>>> at org.geogig.geoserver.spring.config.AbstractDelegatingGeogigM
>>>>>>>> essageConverter.isGeogigPackage(AbstractDelegatingGeogigMess
>>>>>>>> ageConverter.java:34)
>>>>>>>> essageConverter.canWrite(AbstractDelegatingGeogigMessageConv
>>>>>>>> erter.java:50)
>>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Abstra
>>>>>>>> ctMessageConverterMethodProcessor.getProducibleMediaTypes(Ab
>>>>>>>> stractMessageConverterMethodProcessor.java:317)
>>>>>>>> ctMessageConverterMethodProcessor.writeWithMessageConverters
>>>>>>>> (AbstractMessageConverterMethodProcessor.java:184)
>>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Reques
>>>>>>>> tResponseBodyMethodProcessor.handleReturnValue(RequestRespon
>>>>>>>> seBodyMethodProcessor.java:174)
>>>>>>>> at org.springframework.web.method.support.HandlerMethodReturnVa
>>>>>>>> lueHandlerComposite.handleReturnValue(HandlerMethodReturnVal
>>>>>>>> ueHandlerComposite.java:81)
>>>>>>>> at org.springframework.web.servlet.mvc.method.annotation.Servle
>>>>>>>> tInvocableHandlerMethod.invokeAndHandle(ServletInvocableHand
>>>>>>>> lerMethod.java:132)
>>>>>>>> tMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHan
>>>>>>>> dlerAdapter.java:827)
>>>>>>>> tMappingHandlerAdapter.handleInternal(RequestMappingHandlerA
>>>>>>>> dapter.java:738)
>>>>>>>> at org.springframework.web.servlet.mvc.method.AbstractHandlerMe
>>>>>>>> thodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
>>>>>>>> at org.springframework.web.servlet.DispatcherServlet.doDispatch
>>>>>>>> (DispatcherServlet.java:963)
>>>>>>>> at org.springframework.web.servlet.DispatcherServlet.doService(
>>>>>>>> DispatcherServlet.java:897)
>>>>>>>> at org.springframework.web.servlet.FrameworkServlet.processRequ
>>>>>>>> est(FrameworkServlet.java:970)
>>>>>>>> at org.springframework.web.servlet.FrameworkServlet.doPut(Frame
>>>>>>>> workServlet.java:883)
>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
>>>>>>>> at org.springframework.web.servlet.FrameworkServlet.service(Fra
>>>>>>>> meworkServlet.java:846)
>>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
>>>>>>>> at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder
>>>>>>>> .java:808)
>>>>>>>> at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilte
>>>>>>>> r(ServletHandler.java:1669)
>>>>>>>> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(Thr
>>>>>>>> eadLocalsCleanupFilter.java:28)
>>>>>>>> r(ServletHandler.java:1652)
>>>>>>>> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(
>>>>>>>> SpringDelegatingFilter.java:75)
>>>>>>>> at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpB
>>>>>>>> lacklistFilter.java:94)
>>>>>>>> SpringDelegatingFilter.java:71)
>>>>>>>> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.j
>>>>>>>> ava:144)
>>>>>>>> at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFi
>>>>>>>> lter.java:71)
>>>>>>>> at org.geoserver.filters.SpringDelegatingFilter.doFilter(Spring
>>>>>>>> DelegatingFilter.java:46)
>>>>>>>> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(Advan
>>>>>>>> cedDispatchFilter.java:50)
>>>>>>>> at org.springframework.security.web.FilterChainProxy$VirtualFil
>>>>>>>> terChain.doFilter(FilterChainProxy.java:316)
>>>>>>>> at org.geoserver.security.filter.GeoServerCompositeFilter$Neste
>>>>>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>>>> at org.springframework.security.web.access.intercept.FilterSecu
>>>>>>>> rityInterceptor.invoke(FilterSecurityInterceptor.java:126)
>>>>>>>> rityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
>>>>>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>>>> at org.geoserver.security.filter.GeoServerCompositeFilter.doFil
>>>>>>>> ter(GeoServerCompositeFilter.java:92)
>>>>>>>> terChain.doFilter(FilterChainProxy.java:330)
>>>>>>>> at org.springframework.security.web.access.ExceptionTranslation
>>>>>>>> Filter.doFilter(ExceptionTranslationFilter.java:114)
>>>>>>>> at org.geoserver.security.filter.GeoServerAnonymousAuthenticati
>>>>>>>> onFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>>>> at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFi
>>>>>>>> lter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
>>>>>>>> at org.springframework.security.web.authentication.www.BasicAut
>>>>>>>> henticationFilter.doFilterInternal(BasicAuthenticationFilter
>>>>>>>> .java:213)
>>>>>>>> at org.springframework.web.filter.OncePerRequestFilter.doFilter
>>>>>>>> (OncePerRequestFilter.java:107)
>>>>>>>> at org.geoserver.security.filter.GeoServerBasicAuthenticationFi
>>>>>>>> lter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
>>>>>>>> at org.springframework.security.web.context.SecurityContextPers
>>>>>>>> istenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>>>>>>> at org.geoserver.security.filter.GeoServerSecurityContextPersis
>>>>>>>> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFi
>>>>>>>> lter.java:53)
>>>>>>>> at org.springframework.security.web.FilterChainProxy.doFilterIn
>>>>>>>> ternal(FilterChainProxy.java:213)
>>>>>>>> at org.springframework.security.web.FilterChainProxy.doFilter(F
>>>>>>>> ilterChainProxy.java:176)
>>>>>>>> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doF
>>>>>>>> ilter(GeoServerSecurityFilterChainProxy.java:152)
>>>>>>>> at org.springframework.web.filter.DelegatingFilterProxy.invokeD
>>>>>>>> elegate(DelegatingFilterProxy.java:346)
>>>>>>>> at org.springframework.web.filter.DelegatingFilterProxy.doFilte
>>>>>>>> r(DelegatingFilterProxy.java:262)
>>>>>>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.j
>>>>>>>> ava:88)
>>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>>> at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDeb
>>>>>>>> ugFilter.java:48)
>>>>>>>> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilt
>>>>>>>> er.java:44)
>>>>>>>> at org.springframework.web.filter.CharacterEncodingFilter.doFil
>>>>>>>> terInternal(CharacterEncodingFilter.java:197)
>>>>>>>> at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHan
>>>>>>>> dler.java:585)
>>>>>>>> at org.eclipse.jetty.server.handler.ScopedHandler.handle(Scoped
>>>>>>>> Handler.java:143)
>>>>>>>> at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHa
>>>>>>>> ndler.java:577)
>>>>>>>> at org.eclipse.jetty.server.session.SessionHandler.doHandle(Ses
>>>>>>>> sionHandler.java:223)
>>>>>>>> at org.eclipse.jetty.server.handler.ContextHandler.doHandle(Con
>>>>>>>> textHandler.java:1127)
>>>>>>>> at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHand
>>>>>>>> ler.java:515)
>>>>>>>> at org.eclipse.jetty.server.session.SessionHandler.doScope(Sess
>>>>>>>> ionHandler.java:185)
>>>>>>>> at org.eclipse.jetty.server.handler.ContextHandler.doScope(Cont
>>>>>>>> extHandler.java:1061)
>>>>>>>> Handler.java:141)
>>>>>>>> at org.eclipse.jetty.server.handler.HandlerWrapper.handle(Handl
>>>>>>>> erWrapper.java:97)
>>>>>>>> at org.eclipse.jetty.server.Server.handle(Server.java:499)
>>>>>>>> at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java
>>>>>>>> :310)
>>>>>>>> at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConne
>>>>>>>> ction.java:257)
>>>>>>>> at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnec
>>>>>>>> tion.java:540)
>>>>>>>> at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(Queued
>>>>>>>> ThreadPool.java:635)
>>>>>>>> at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedT
>>>>>>>> hreadPool.java:555)
>>>>>>>> at java.lang.Thread.run(Unknown Source)
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> Check out the vibrant tech community on one of the world's most
>>>>>>>> engaging tech sites, Slashdot.org! http://sdm.link/slashdot
>>>>>>>> _______________________________________________
>>>>>>>> Geoserver-devel mailing list
>>>>>>>> Geoserver-devel at lists.sourceforge.net
>>>>>>>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171018/7158974a/attachment-0001.html>
More information about the geonode-devel mailing list
