[GeoNode-devel] Print template with geonode-client
Francesco Bartoli xbartolone at gmail.com
Fri Oct 20 10:07:59 PDT 2017
Hi Paolo,
since it is using boundless sdk 1.0 you can have a look at this example https://github.com/boundlessgeo/sdk/tree/b5f923ffdcd353fdf4cb5f4a6ae6c4ab6b7c1b97/examples/export-image or even the other from their sdk-apps https://github.com/boundlessgeo/sdk-apps/tree/master/tabbed for more information but it looks like there’s no documentation and the template is basic.
You can also have a look at the online application with the print feature here http://boundlessgeo.github.io/sdk-apps/tabbed/#map=9783.93962050256/-16839563.6/8850169.51/0
Ciao
Francesco
Il giorno 20/ott/2017, alle ore 15:57, Paolo Pasquali <paolo.pasquali at gmail.com> ha scritto:
> Hi devs,
> I'm using the geonode-client and I would like to customize my print template but I can't find the documentation.
> I've seen an old issue on this https://github.com/GeoNode/geonode-client/issues/46 but no updates since.
> I've been playing with MapFish config.yaml (following the GeoNode and GeoServer docs) but it seems the geonode-client is not using it.
> Any hint on this?
> Thanks!
> Ciao
> Paolo
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171020/4204eb0c/attachment.html>
More information about the geonode-devel mailing list
