[GeoNode-devel] Grouping layers in maps
Paolo Corti pcorti at gmail.com
Thu Oct 26 11:53:12 PDT 2017
Hello Kevin
WorldMap forked GeoExplorer version has this feature, you could have a
look at it:
http://worldmap.harvard.edu/boston/
though, it is not possible to turn on/off the display of a group, but
I suspect it should be not difficult to implement it
source code is here:
https://github.com/cga-harvard/cga-worldmap/tree/legacy/src/geonode-client
cheers
p
On Thu, Oct 26, 2017 at 10:13 AM, Côté, Kevin <Kevin.Cote at wsp.com> wrote:
> Hi,
> I’d like to have the possibility to create layer groups in maps as we can do
> in QGIS.
> I need to be able to toggle the visibility of each layers inside a group
> (therefore, the GeoServer layer groups doesn’t work because only the whole
> group can be toggled). I need this because I’ll create maps with sometimes
> 30-40 layers in 3-4 layer groups.
> Is this functionality available within GeoExplorer ? Is there a way to
> achieve this with the actual platform without too much development ?
> Thank you
> Kevin
> ________________________________
> NOTICE: This communication and any attachments ("this message") may contain
> information which is privileged, confidential, proprietary or otherwise
> subject to restricted disclosure under applicable law. This message is for
> the sole use of the intended recipient(s). Any unauthorized use, disclosure,
> viewing, copying, alteration, dissemination or distribution of, or reliance
> on, this message is strictly prohibited. If you have received this message
> in error, or you are not an authorized or intended recipient, please notify
> the sender immediately by replying to this message, delete this message and
> all copies from your e-mail system and destroy any printed copies. You are
> receiving this communication because you are listed as a current WSP
> contact. Should you have any questions regarding WSP's electronic
> communications policy, please consult our Anti-Spam Commitment at
> www.wsp.com/casl. For any concern or if you believe you should not be
> receiving this message, please forward this message to
> caslcompliance at wsp.com so that we can promptly address your request. Note
> that not all messages sent by WSP qualify as commercial electronic messages.
> AVIS : Ce message, incluant tout fichier l'accompagnant (« le message »),
> peut contenir des renseignements ou de l'information privilégiés,
> confidentiels, propriétaires ou à divulgation restreinte en vertu de la loi.
> Ce message est destiné à l'usage exclusif du/des destinataire(s) voulu(s).
> Toute utilisation non permise, divulgation, lecture, reproduction,
> modification, diffusion ou distribution est interdite. Si vous avez reçu ce
> message par erreur, ou que vous n'êtes pas un destinataire autorisé ou
> voulu, veuillez en aviser l'expéditeur immédiatement et détruire le message
> et toute copie électronique ou imprimée. Vous recevez cette communication
> car vous faites partie des contacts de WSP. Si vous avez des questions
> concernant la politique de communications électroniques de WSP, veuillez
> consulter notre Engagement anti-pourriel au www.wsp.com/lcap. Pour toute
> question ou si vous croyez que vous ne devriez pas recevoir ce message,
> prière de le transférer au conformitelcap at wsp.com afin que nous puissions
> rapidement traiter votre demande. Notez que ce ne sont pas tous les messages
> transmis par WSP qui constituent des messages electroniques commerciaux.
> -LAEmHhHzdJzBlTWfa4Hgs7pbKl
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
