[GeoNode-devel] running tests conditionally
Paolo Corti pcorti at gmail.com
Tue Sep 5 07:06:56 PDT 2017
Hi Simone
I was considering to have the application installed by default. But
yes, it makes sense to leave it out from INSTALLED_APPS (though I
think most of us use PostgreSQL/PostGIS), and have the test running
only it is there
cheers
p
On Fri, Sep 1, 2017 at 3:50 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Ciao Paolo,
> what about adding tests and specific settings for database in your contrib
> app? When activating the app you will have to add it to the INSTALLED_APPS
> and also add from geonode.contrib.yourapp.settings import *
> This way the db will become postgres and the tests of the app will run.
> We did something similar for contrib.mp
> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/mp
> 2017-08-31 22:32 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Hi devs
>> I have a test module which needs to test a contrib application
>> (createlayer, [1]) which requires PostgreSQL and an existing PostGIS
>> database on the system.
>> I am planning to have the test module for this contrib application
>> called from paver only in the case that the conditions are met. Any
>> good idea to implement this?
>> thanks and cheers
>> p
>> [1] https://github.com/capooti/geonode/tree/create-layer-app
>> Paolo Corti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
