[GeoNode-devel] Clarifications on GeoNode branches, version numbers and deb packages
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 7 04:55:38 PDT 2017
+1
Can you take care of modifying pavement or you need me to do it?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Sep 7, 2017 at 1:29 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Dears as I agree in principles with Angelos and Alessio who made this PR
> https://github.com/GeoNode/geonode/pull/3270/files, I think that in
> parallel we should also change pavement.py to handle the alpha, beta and
> final tag better. With that PR, which respects our idea, I'm afraid that
> ppl who don't know about our convention think that 2.9 is a final stable
> release. Should we introduce the tag "unstable" for odd version instead? We
> could remove the tag at all but then we loose the abiliti to do beta and rc
> releases.
> 2017-09-07 11:17 GMT+02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> I think we could skip the ".alpha.0" part for ppa:geonode/unstable and
>> just release 2.7.0 etc.
>> Regards,
>> Angelos
>> On 09/07/2017 11:22 AM, Alessio Fabiani wrote:
>> Dear all,
>> after a talk with Simone Dalmasso, which clarified to me how GeoNode
>> project manages versioning and branchning, I'm going to summarize here the
>> current status on this topic on the next steps.
>>  - GeoNode odd version number are considered "unstable", which means they
>> must be tested before promoted to a stable one. Therefore currently the
>> 2.7.x is unstable and after the testing cycle it will be promoted to 2.8.x
>> - GeoNode branch 2.7.x will contain versions which will be published to
>> Launchapd and Pypi. Currently the version we need to release on
>> "ppa:geonode/unstable" should be the "2.7.0.alpha.0"
>> - GeoNode "master" branch should instead be bumped to 2.9dev version
>> - After the testing cycle, once the 2.7.x will be considered stable, we
>> will need to bump it to 2.8.0 and release on "ppa:geonode/testing" while in
>> alpha and beta and "ppa:geonode/stable" when in rc and final state
>> Did I miss something? Any other consideration or things to add?
>> Regards,
>> Alessio Fabiani
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.ithttp://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing listgeonode-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Angelos Tzotsos, PhD
>> Charter Member
>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/a3b93c19/attachment-0001.html>
More information about the geonode-devel mailing list
