[GeoNode-devel] Using geonode-updateip with a custom geonode-project
Dave Kennewell davekennewell at gmail.com
Wed Sep 13 02:10:45 PDT 2017
OK, I think I got to the bottom of this issue.
Setting DJANGO_SETTINGS_MODULE variable wasn't working because python's
sys.path first looks for modules in the *current working directory*, then
looks to system-wide modules on PYTHONPATH. DJANGO_SETTINGS_MODULE is found
on PYTHONPATH.
In the *current working directory* for the geonode-updateip command
(/usr/sbin) is a script called "geonode" which sys.path is finding first.
This sets the settings to geonode.settings rather than
mygeonodeproject.settings, before django ever looks on PYTHONPATH. This
one:
https://github.com/GeoNode/geonode/blob/2.6.x/package/support/geonode.binary
I modified this file to use mygeonodeproject.settings and everything works
as expected now, thanks for the help.
I don't know how to structure a Pull Request to address this when using
geonode-project. I've simply updated my deployment scripts to do this at
build-time. Thoughts welcome here.
regards
Dave
On 8 September 2017 at 17:11, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Yes this is the behaviour that I would expect with the current setup.
> geonode-updateip is using the geonode default settings because is in the
> geonode root. While python manage.py shell from your project correctly sets
> your project settings.
> You could try to set the DJANGO_SETTINGS_MODULE as a permanent
> environment variable for root (added in home/root/.bashrc or bash_profile
> for example.
> 2017-09-08 14:56 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>> Hi Rob  - let me have a look at this concept once I solve this immediate
>> challenge :)
>> Hi Simone,
>> OK, so I tested this and
>> os.environ['DJANGO_SETTINGS_MODULE'] = 'mygeonodeproject.settings'
>> works to set the settings module correctly. We were correct -
>> fixoauthuri.py was pulling settings from geonode.settings not
>> mygeonodeproject.settings. But this doesn't solve the issue unfortunately.
>> It's still importing the people.profile model from the local database, not
>> the remote one.
>> To further debug, I opened the django shell as my geonode user (in my
>> case it's "ubuntu")
>> from /home/ubuntu/mygeonodeproject, and ran the commands from
>> fixoauthuri.py. This worked fine - they pick up my superuser created on the
>> remote database.
>> So, this leads me to believe the problem lies with fixoauthuri.py being
>> run as "root" user when called using "sudo geonode-updateip myIpAddress".
>> But I'm stuck as to further reasons why this is the problem.
>> To be specific:
>> When I use
>> from geonode.people.models import Profile
>> as *root from "sudo geonode-updateip"*, it imports Profile from the
>> local database.
>> When I use
>> as *ubuntu from the shell,* it imports Profile from the remote database.
>> And just for completeness, when I use
>> as *root from the shell *("sudo python manage.py shell"), it imports
>> Any ideas how to remedy this one?
>> On 8 September 2017 at 10:59, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>>> Hi Dave,
>>> good catch, we need to fix this. I guess an approach like manage.py is
>>> using https://github.com/GeoNode/geonode-project/blob/2.6/manage.py#L10,
>>> added before the import could work but needs to be tested...
>>> Let me know
>>> 2017-09-07 18:32 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>>> Hi Geonode Devs,
>>>> I'm using geonode 2.6.3 installed by apt-get on a fresh ubuntu 16.04
>>>> instance.
>>>> On top of this I install geonode-project, and customise settings.py in
>>>> mygeonodeproject.
>>>> This works fine if I use the postgres database that apt-get
>>>> automatically installs locally on my geonode server.
>>>> However, when I go to swap out this local database with a remote one
>>>> (it's on AWS RDS), it's all good until the command "sudo geonode-updateip
>>>> mygeonodeproject.com" tells me I don't have a superuser created (I do,
>>>> but it's on the remote database, created using the manage.py command in
>>>> mygeonodeproject folder).
>>>> When I drill into this a bit deeper, it appears to come down to this
>>>> line:
>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>> anagement/commands/fixoauthuri.py#L33
>>>> This line ("from django.conf import settings") is pulling in models
>>>> from the local geonode database, not the remote RDS database I'm using for
>>>> mygeonodeproject.
>>>> What am I doing wrong here, and what is the best way to import my
>>>> custom project into this command rather than the globally installed
>>>> geonode, when using "from django.conf import settings"?
>>>> thanks for any help
>>>> regards
>>>> Dave
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170913/4d782a62/attachment-0001.html>
More information about the geonode-devel mailing list
