[GeoNode-devel] Commit code in GeoNode master branch
Simone Dalmasso simone.dalmasso at gmail.com
Tue Sep 19 04:04:19 PDT 2017
Hi Dimitris,
I would definitely see this contribution as part of the core codebase
rather that having it as contrib optional app. Therefore I'm +1 in keeping
the js into layer_detail.html, while for css you could add it to the
base.less (that then you can compile minified into base.css).
If you have tests, the better but being mostly js, as I suppose, it's ok
without them as well as we don't have testing facilities in place for js.
While for the doc, it is in a dedicated folder into the main repo
https://github.com/GeoNode/geonode/tree/master/docs, you can find the most
convenient place in there.
Thanks a lot for this, very nice and welcome feature.
Let us know if you need further info.
Ciao
2017-09-19 10:33 GMT+02:00 Dimitris Karakostis <
karakostis.dimitris at gmail.com>:
> Hi all,
> I have integrated the Layer Filtering functionality in my local master
> branch of GeoNode. The functionality gives the possibility to build basic
> queries based on the layer's attributes and values and download part of the
> layers (in the provided formats) (see screenshot). Currently it works for
> local, vector layers.
> In the past we have discussed this functionality here:
> https://goo.gl/7rTDzF
> As this is my first contribution to the GeoNode community, I want to be
> sure that the commit complies to best practices in terms of documentation,
> potential tests and code.
> Currently I have included CSS and javascript code in the
> layer_detail.html. Should I move these snippets of code in external files?
> How and where do I update the documentation?
> Any advice on the above would be greatly appreciated.
> Thanks.
> Dimitris
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170919/8e9724e6/attachment.html>
More information about the geonode-devel mailing list
