[GeoNode-devel] Native SRS ignored
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Sep 20 10:35:07 PDT 2017
Could you check the configuration of the Layer in GeoServer? It is possible
that it is stored into native CRS but projected by GeoNode into the
selected CRS.
However there are plans for GeoNode 3.0 to improve such behavior.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Sep 20, 2017 at 1:16 PM, <amagislist at oicom.com> wrote:
> Hi everybody,
> this is something I can't understand...
> I add a PostGIS layer to GeoServer with both native and declared SRS
> correctly set to EPSG:3003.
> I then create a new GeoNode Layer upon it (via the manage.py updatelayers
> command).
> If I download the GeoNode Layer as a zipped Shape file, data inside it is
> indeed in native EPSG:3003 SRS,
> but if I look at Layer's Metadata, the SRS is shown as EPSG:4326.
> Even looking into the Django Admin page for a Layer, the SRID is shown as
> set to EPSG:4326,
> it seems there's no way in GeoNode to see the native SRS of a Leyer... :-o
> Is this correct, or there's something wrong with my setup?
> How can I make Users see the native SRS of each layer?
> Bye
> Paolo
> GeoNode <http://geonode.org>
> *2.6.1 *GeoServer
> *2.7.4 *
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170920/a00012fb/attachment.html>
More information about the geonode-devel mailing list
