[GeoNode-devel] GeoNode monitoring
Paolo Corti pcorti at gmail.com
Thu Sep 28 13:08:09 PDT 2017
Hi Cezary
it is a great work, thanks a lot!
I am having a try, and I could successfully install and configure it. But
the console is not fed with monitoring data, and I see in the Django
log lot of lines (one every minute, as the default frequency) like
this:
[28/Sep/2017 15:04:34] "GET
/monitoring/api/metric_data/response.error.count/?last=undefined&interval=undefined
HTTP/1.1" 400 123
Any idea?
cheers
ps I added some comment in your PR. Maybe I will add others once I can
make it working :)
p
On Thu, Sep 28, 2017 at 5:25 AM, cezary.statkiewicz at geo-solutions.it
<cezary.statkiewicz at geo-solutions.it> wrote:
>  Hi,
>  I've pushed GeoNode monitoring app, there's PR pending:
> https://github.com/GeoNode/geonode/pull/3322 (it's big). Could you review?
>  Main functionality is in geonode.contrib.monitoring app:
> https://github.com/geosolutions-it/geonode/tree/monitoring/geonode/contrib/monitoring,
> although there are few changes in core, so monitoring could get events from
> it.
>  This code works with current master. For older versions, a backport is
> needed. However, due to core hooks, it may be hard to get exactly the same
> functionality. I think backport may have limited  functionality (in terms:
> it would collect less data).
>  Looking forward for comments and feedback.
> Regards,
> Cezary Statkiewicz
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Cezary Statkiewicz
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes made
> after they were sent or for other risks which arise as a result of e-mail
> transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
