[GeoNode-devel] [GeoNode-users] GeoNode 2.8.0 is out!
Francesco Bartoli xbartolone at gmail.com
Tue Apr 3 12:34:21 PDT 2018
Great Alessio! This has been demanding from the wider community and now it allows to move things forward focusing on a LTS as agreed during the summit.
Thanks again
Francesco
Il 3 apr 2018, 19:59 +0200, Bernard Justus Muhwezi <bernard.muhwezi at gmail.com>, ha scritto:
> Alessio,
> Just as promised, bravo dear man of effort. We congratulate and salute the much energy that goes into this accomplishment.
> Dear all you are appreciated from this part of the globe.
> Bernard Justus
> > On Tue, Apr 3, 2018 at 2:31 PM, Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> > > Dear all,
> > > GeoNode release 2.8.0 is out!
> > > Installing from apt on Ubuntu 16.04
> > > In order to test it through APT, on a clean Ubuntu 16.04 instance run:
> > > sudo apt-add-repository ppa:geonode/testing
> > > sudo apt update -y
> > > sudo apt upgrade -y
> > > sudo apt install geonode
> > > Few notes on finalizing the setup (this will be improved on next release)
> > > 1) Update your default map crs to 3857
> > >   sudo nano /etc/geonode/local_settings.py
> > >     DEFAULT_MAP_CRS = "EPSG:3857"
> > >     DEFAULT_LAYER_FORMAT = "image/png8"
> > >   sudo service apache2 restart
> > > 2) Restart Tomcat in order to allow GeoServer to reload the configuration
> > >   sudo service apache tomcat8 restart
> > > Setting up your custom project
> > > Please follow instructions from
> > > https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
> > > Upgrading from 2.6.x release
> > > If you would like to update from a 2.6.x development version, please take a look at the following document (still not definitive)
> > > http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
> > > Other type of setup / installer
> > > Docker and Windows installers won't be ready by the announcement of the official release.
> > > There are still many issues with those two packages, preventing us to publish stable versions of them.
> > > Regards,
> > > Alessio Fabiani
> > > GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> > > Ing. Alessio Fabiani
> > > @alfa7691
> > > Founder/Technical Lead
> > > GeoSolutions S.A.S.
> > > Via di Montramito 3/A
> > > 55054  Massarosa (LU)
> > > Italy
> > > phone: +39 0584 962313
> > > fax:     +39 0584 1660272
> > > mob:   +39 331 6233686
> > > http://www.geo-solutions.it
> > > http://twitter.com/geosolutions_it
> > > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > > Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> > > The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> > > _______________________________________________
> > > geonode-users mailing list
> > > geonode-users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180403/8d186ab8/attachment-0001.html>
More information about the geonode-devel mailing list
