[GeoNode-devel] [GeoNode-users] GeoNode 2.8.0 is out!
Paolo Corti pcorti at gmail.com
Tue Apr 3 14:01:03 PDT 2018
Excellent
Thanks Alessio and to all GeoNode developers, users and the rest of
the community, it is a great project!
Paolo
On Tue, Apr 3, 2018 at 4:06 PM, Lewis, Benjamin <blewis at cga.harvard.edu> wrote:
> Thanks Alessio and the global geonode team!
> From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On Behalf
> Of Alessio Fabiani
> Sent: Tuesday, April 3, 2018 7:31 AM
> To: geonode-users <geonode-users at lists.osgeo.org>; geonode-devel
> <geonode-devel at lists.osgeo.org>
> Subject: [GeoNode-users] GeoNode 2.8.0 is out!
> Dear all,
> GeoNode release 2.8.0 is out!
> Installing from apt on Ubuntu 16.04
> In order to test it through APT, on a clean Ubuntu 16.04 instance run:
> sudo apt-add-repository ppa:geonode/testing
> sudo apt update -y
> sudo apt upgrade -y
> sudo apt install geonode
> Few notes on finalizing the setup (this will be improved on next release)
> 1) Update your default map crs to 3857
>   sudo nano /etc/geonode/local_settings.py
>     DEFAULT_MAP_CRS = "EPSG:3857"
>     DEFAULT_LAYER_FORMAT = "image/png8"
>   sudo service apache2 restart
> 2) Restart Tomcat in order to allow GeoServer to reload the configuration
>   sudo service apache tomcat8 restart
> Setting up your custom project
> Please follow instructions from
> https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
> Upgrading from 2.6.x release
> If you would like to update from a 2.6.x development version, please take a
> look at the following document (still not definitive)
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
> Other type of setup / installer
> Docker and Windows installers won't be ready by the announcement of the
> official release.
> There are still many issues with those two packages, preventing us to
> publish stable versions of them.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
