[GeoNode-devel] Geonode 2.8 in Vagrant
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Apr 6 01:34:31 PDT 2018
Hi guys,
would you have some time to update documentation with this vagrant stuff?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-04-06 10:02 GMT+02:00 Pieter du Plooy <pjduplooy.gis at gmail.com>:
> Hi Toni
> Thanks for all your help and guidance.  Geonode 2.8 is now running in
> vagrant perfectly, without having localhost exposed.  Private networking is
> such a clever way! I will probably be using vagrant with private networking
> more.  By the way, I have started to "vagrantize" geohelm (geohelm.org)
> as a proof of concept using private networking.
> On a side note have you used Cartoview yet?  That is one project that I
> really want to use (as "extension" to Geonode), but have always been unable
> to do so, especially in vagrant or docker.  I think that might be a good
> project to install natively on Mac using your gist.
> Anyway, Thanks again.
> Pieter
> On Thu, Apr 5, 2018 at 12:17 PM, Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Hey Pieter,
>> yes Homebrew is installed here. But regarding geonode I did not any
>> installation else except those
>> mentioned in the gist. But I´ve installed qgis (
>> http://www.kyngchaos.com/software/qgis)
>> This installes some packages as well. Means If something is missing after
>> you´ve run through
>> the gist this could be the reason.
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 73
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 05.04.2018 um 11:44 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com>:
>> Hi Toni
>> Thanks for all the valuable info.  Last question though, did you install
>> anything else like homebrew or macports packages for you Geonode OSX
>> install"
>> Pieter
>> On Thu, Apr 5, 2018 at 9:35 AM, Toni Schönbuchner <
>>> Hi Pieter,
>>> So what your saying is that if my router's address range is
>>> 192.168.1.xxx, I could tell vagrant that I want to use 192.168.1.33 (or
>>> whatever as last part), and thats that?
>>> Exactly. After you´ve '$ vagrant up' have a look at virtualbox network
>>> setup. You will see a second network interface
>>> further check /etc/network/interfaces on your vm. Vagrant did the „hard“
>>> work for you. Of course you can change the ip
>>> to your needs.
>>> https://gist.github.com/t-book/e05e2b3905356e9a51fe7d6fa187ad4d
>>> Any case, thanx so much for your help…
>>> You´re welcome.
>>> I also saw that you are trying to get to run geonode on OSX, Any luck
>>> with that?
>>> Yes this is how I did:
>>> By the way, a Geonode install from PPA, can I use ubuntugis-unstable as
>>> the repo for the gdal, and postgis stuff?
>>> I have not tried yet but why? The package should install all which is
>>> needed?
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Web http://csgis.de
>>> Am 05.04.2018 um 08:27 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com
>>> Hi Toni
>>> Any case, thanx so much for your help...  O I also saw that you are
>>> trying to get to run geonode on OSX, Any luck with that?
>>> Regards.
>>> Pieter
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180406/8fdfea90/attachment-0001.html>
More information about the geonode-devel mailing list
