[GeoNode-devel] Problem style's visualization
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 6 06:42:11 PDT 2018
Hi, which is the issue you are facing? Geoserver 2.9 doesn't have full
compatibility with qgis generated SLD, but if you see it correctly in
geoserver then it should to 100% the same in geonode
2018-04-06 11:07 GMT+02:00 Openquake.org <armando at openquake.org>:
> Good Morning,
> i have a problem with style's visualization when import the project from
> qgis.
> I use Geonode 2.6 and Geoserver 2.9-SNAPSHOT.
> In Geoserver the style is perfectly but in Geonode the style's
> visualization fails.
> How could I solve this problem?
> Thanks
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180406/4dbcb88a/attachment.html>
More information about the geonode-devel mailing list
