[GeoNode-devel] [GeoNode-users] GeoNode 2.8.0 is out!
Federico Gianoli alpacagis at gmail.com
Tue Apr 17 02:29:04 PDT 2018
Hi Elton,
try to re-run apt-get install geonode,
Once I had the same error and I solved in this way.
Regards
Federico
2018-04-16 19:10 GMT+02:00 Elton Davis Turin Espinoza <eturine at uni.pe>:
> Hi all,
> I just installed Geonode 2.8 stable and it is not operational, in the
> installation process is message out 'ImportError: No module named
> geonode.settings'.
> Can you please tell me how to make it work?
> I executed:
> sudo add-apt-repository ppa: geonode / stable
> sudo apt-get update
> sudo apt-get install geonode
> sudo geonode-updateip 35.229.115.147
> Please help me
> Thank you
> Elton
> 2018-04-03 16:01 GMT-05:00 Paolo Corti <pcorti at gmail.com>:
>> Excellent
>> Thanks Alessio and to all GeoNode developers, users and the rest of
>> the community, it is a great project!
>> Paolo
>> On Tue, Apr 3, 2018 at 4:06 PM, Lewis, Benjamin <blewis at cga.harvard.edu>
>> wrote:
>> > Thanks Alessio and the global geonode team!
>> > From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On
>> Behalf
>> > Of Alessio Fabiani
>> > Sent: Tuesday, April 3, 2018 7:31 AM
>> > To: geonode-users <geonode-users at lists.osgeo.org>; geonode-devel
>> > <geonode-devel at lists.osgeo.org>
>> > Subject: [GeoNode-users] GeoNode 2.8.0 is out!
>> > Dear all,
>> > GeoNode release 2.8.0 is out!
>> > Installing from apt on Ubuntu 16.04
>> > In order to test it through APT, on a clean Ubuntu 16.04 instance run:
>> > sudo apt-add-repository ppa:geonode/testing
>> > sudo apt update -y
>> > sudo apt upgrade -y
>> > sudo apt install geonode
>> > Few notes on finalizing the setup (this will be improved on next
>> release)
>> > 1) Update your default map crs to 3857
>> >   sudo nano /etc/geonode/local_settings.py
>> >     DEFAULT_MAP_CRS = "EPSG:3857"
>> >     DEFAULT_LAYER_FORMAT = "image/png8"
>> >   sudo service apache2 restart
>> > 2) Restart Tomcat in order to allow GeoServer to reload the
>> configuration
>> >   sudo service apache tomcat8 restart
>> > Setting up your custom project
>> > Please follow instructions from
>> > https://github.com/GeoNode/geonode-project#using-a-python-
>> virtual-environment
>> > Upgrading from 2.6.x release
>> > If you would like to update from a 2.6.x development version, please
>> take a
>> > look at the following document (still not definitive)
>> > http://docs.geonode.org/en/master/tutorials/install_and_admi
>> n/geonode_update/26_to_27/index.html#update-from-geonode-2-
>> 6-3-to-geonode-2-7
>> > Other type of setup / installer
>> > Docker and Windows installers won't be ready by the announcement of the
>> > official release.
>> > There are still many issues with those two packages, preventing us to
>> > publish stable versions of them.
>> > Regards,
>> > Alessio Fabiani
>> > GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V
>> > for more information.
>> > Ing. Alessio Fabiani
>> > @alfa7691
>> > Founder/Technical Lead
>> > GeoSolutions S.A.S.
>> > Via di Montramito 3/A
>> > 55054  Massarosa (LU)
>> > Italy
>> > phone: +39 0584 962313
>> > fax:     +39 0584 1660272
>> > mob:   +39 331 6233686
>> > http://www.geo-solutions.it
>> > http://twitter.com/geosolutions_it
>> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> > Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i
>> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
>> le
>> > finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio
>> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>> notizia
>> > via e-mail e di procedere alla distruzione del messaggio stesso,
>> > cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo
>> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per
>> > finalità diverse, costituisce comportamento contrario ai principi
>> dettati
>> > dal D.Lgs. 196/2003.
>> > The information in this message and/or attachments, is intended solely
>> for
>> > the attention and use of the named addressee(s) and may be confidential
>> or
>> > proprietary in nature or covered by the provisions of privacy act
>> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> > Code).Any use not in accord with its purpose, any disclosure,
>> reproduction,
>> > copying, distribution, or either dissemination, either whole or
>> partial, is
>> > strictly forbidden except previous formal approval of the named
>> > addressee(s). If you are not the intended recipient, please contact
>> > immediately the sender by telephone, fax or e-mail and delete the
>> > information in this message that has been received in error. The sender
>> does
>> > not give any warranty or accept liability as the content, accuracy or
>> > completeness of sent messages and accepts no responsibility  for changes
>> > made after they were sent or for other risks which arise as a result of
>> > e-mail transmission, viruses, etc.
>> > _______________________________________________
>> > geonode-devel mailing list
>> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
> entidad que se muestra como destinatario/s y pueden contener datos
> personales y/o información confidencial, sometida a secreto profesional o
> cuya divulgación esté prohibida en la legislación vigente. Que
> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación, reproducción
> u otra acción al respecto por parte de personas o entidades  distintas al
> destinatario/s. Si ha recibido este mensaje por error, por favor,
> contáctenos a la siguiente dirección de correo electrónico lpdp at uni.edu.pe
> y proceda a su eliminación.
> En cumplimiento a lo establecido en la Ley de Protección de Datos
> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
> son almacenados bajo la confidencialidad y las medidas de seguridad
> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
> usted podrá ejercitar los derechos de actualización,
> inclusión, rectificación, supresión u oposición, enviando un mensaje al
> correo electrónico anteriormente señalado e indicando en el "Asunto" el
> derecho que desea ejercer"
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180417/9ed648fc/attachment.html>
More information about the geonode-devel mailing list
