[GeoNode-devel] Thumbnail generation issue for layer in non EPSG:4326 projection
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 2 09:13:10 PST 2018
Created an issue here
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-01-23 10:28 GMT+01:00 Peter Marlow <Peter.Marlow at scisys.co.uk>:
> Hi,
> I’ve encountered an issue where I’m getting GeoNode to generate layer
> thumbnails as part of the *updatelayers* command. The problem I have is
> that when I configure the layer in GeoServer in order to get a valid
> thumbnail produced I then lose the ability to filter by extent for that
> layer in GeoNode. I believe this is because the layer in question is in a
> UK projection system and not EPSG:4326.
> In order to get a valid thumbnail produced I have to set the following
> properties in GeoServer:
> However with these details set when I filter by extent in GeoNode using
> either the API or web interface the layer is no longer returned (example
> filter: http://<geonode_host>/layers/?limit=100&offset=0&extent=-6.
> 899414062500001,48.07807894349862,4.658203125000001,56.145549500679074)
> I think this is because the extent being provided via the filter is in
> EPSG:4326 (as this is what GeoNode supports) but the lat/lon Bounding Box
> in GeoServer is in EPSG:27700. If I change the Lat/Lon Bounding Box to be
> EPSG:4326 coordinates in GeoServer then I get a blank white image generated
> for the thumbnail and the extent filter starts working again.
> I’ve tried all the combinations and SRS Handling, Native Bounding Box and
> Lat/Lon Bounding Box but I cannot get a valid thumbnail and the extent
> filter to work at the same time.
> Is what I’m trying to do possible? Thanks in advance for any feedback!
> Thanks,
> Pete
> <http://gfidisc.scisys.co.uk>
> SCISYS UK Limited. Registered in England and Wales No. 4373530.
> Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
> Before printing, please think about the environment.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180202/a3639f63/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180202/a3639f63/attachment-0001.png>
More information about the geonode-devel mailing list
