[GeoNode-devel] Download filter not working
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 12 01:36:24 PST 2018
Hi Jhonatan,
let's make sure issues are opened for all those bugs.
I'll try to find some time to take a look at them. Hopefully someone else
could try to propose a solution sooner.
Thanks for testing.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-02-10 13:39 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
> Hi Alessio
> Another bug I’ve raised as issue #3609
> <https://github.com/GeoNode/geonode/issues/3609>:
> On version 2.8rc11, from a layer page, Download Layer > Data tab: entering
> a filter and/or feature limit has no effect (on the download URLs).
> Selecting an attribute gives a Chrome Dev Console error e.g. "Uncaught
> TypeError: Cannot read property 'STATE_CODE' of undefined".
> Clicking "+" after entering an operator and value gives "Uncaught
> TypeError: $(...).select2(...).text.trim is not a function".
> Regards
> Jonathan
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180212/bca8f26c/attachment.html>
More information about the geonode-devel mailing list
