[GeoNode-devel] 2.8rc11 API errors
Paolo Pasquali paolo.pasquali at gmail.com
Thu Feb 15 03:23:35 PST 2018
Oops!
I've missed Dave's reply. I'm going to check my tastypie version.
Best,
P.
On Thu, Feb 15, 2018 at 12:21 PM, Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> Hi,
> I'm getting the same error as Dave's.
> I've installed the 2.7.x branch in a virtualenv+Postgresql+GeoServer2.12.x
> on Ubuntu 16.04
> Is there a way to solve this issue without giving up my installation?
> Thanks,
> Paolo
> On Mon, Feb 12, 2018 at 3:28 AM, Jonathan Doig <j.doig at unsw.edu.au> wrote:
>> Hi Dave
>> Those API URLs work fine for me on a fresh 2.8rc11 installed last week
>> per Alessio’s instructions (attached).
>> I’m using a bare Ubuntu 16.04 on AWS EC2 tx2-large: 16 GB RAM,  4 cores.
>> Jonathan
>> *From:* geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] *On
>> Behalf Of *Dave Kennewell
>> *Sent:* Sunday, 11 February 2018 9:55 PM
>> *To:* geonode-devel <geonode-devel at lists.osgeo.org>
>> *Subject:* [GeoNode-devel] 2.8rc11 API errors
>> Hi all,
>> I'm testing 2.8rc11, and any call to the /api/base or /api/layers or
>> /api/maps endpoint gives the following error:
>> Internal Server Error: /api/layers/
>>  Traceback (most recent call last):
>>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 211, in wrapper
>>      response = callback(request, *args, **kwargs)
>>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 438, in dispatch_list
>>      return self.dispatch('list', request, **kwargs)
>>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 470, in dispatch
>>      response = method(request, **kwargs)
>>    File "/usr/local/lib/python2.7/dist-packages/geonode/api/resourcebase_api.py", line 666, in get_list
>>      **self.remove_api_resource_names(kwargs))
>>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 2100, in obj_get_list
>>      applicable_filters = self.build_filters(filters=filters)
>>    File "/usr/local/lib/python2.7/dist-packages/geonode/api/resourcebase_api.py", line 134, in build_filters
>>      filters=filters, ignore_bad_filters=False, **kwargs)
>>  TypeError: build_filters() got an unexpected keyword argument 'ignore_bad_filters'
>> Can someone replicate this or is it my config error?
>> thanks
>> Dave
>> ---------- Forwarded message ----------
>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>> To: Paolo Corti <pcorti at gmail.com>
>> Cc: geonode-devel <geonode-devel at lists.osgeo.org>
>> Bcc:
>> Date: Fri, 19 Jan 2018 13:19:32 +0000
>> Subject: Re: [GeoNode-devel] Move to Release 2.8
>> Release process ongoing.
>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04 instance
>> just run the following commands
>> sudo add-apt-repository ppa:geonode/testing
>> sudo apt update
>> sudo apt install geonode
>> geonode createsuperuser
>> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
>> sudo geonode-updateip $IP_ADDRESS
>> sudo service apache2 restart
>> This is still under testing, so 1. do not try this on production servers
>> - or on server where you have installations you don't want to break ; 2. it
>> is possible that something goes wrong - in this case please report to me
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>>> +1!
>>> of course
>>> Paolo
>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>> <xbartolone at gmail.com> wrote:
>>> > Hi Rizky,
>>> > yes you should backport it to 2.7.x which will become 2.8.0 then.
>>> > Ciao
>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>> > <rizky at kartoza.com> ha scritto:
>>> > +1
>>> > Can I also know how are you going to release 2.8? Is it coming from
>>> 2.7.x
>>> > branch? I would like to include qgis-server backend if possible, but
>>> that
>>> > depends on how much effort that would be. At the moment, only master
>>> branch
>>> > have qgis-server backend.
>>> > Software Developer
>>> > Kartoza.com
>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>>> >> +1
>>> >> ..Tom
>>> >> Sent from my iPhone
>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <simone.dalmasso at gmail.com
>>> >> wrote:
>>> >> +1!
>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <
>>> jcooper at jeremiahcooper.com>:
>>> >>> +1.
>>> >>> Thanks.
>>> >>> Jeremiah Cooper
>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>> >>> <alessio.fabiani at geo-solutions.it> wrote:
>>> >>>> +1
>>> >>>> Regards,
>>> >>>> Alessio Fabiani
>>> >>>> @alfa7691
>>> >>>> GeoSolutions S.A.S.
>>> >>>> Italy
>>> e/o
>>> riservate. Il loro
>>> per le
>>> messaggio
>>> >>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>>> notizia
>>> >>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>> divulgarlo
>>> utilizzarlo per
>>> >>>> finalità diverse, costituisce comportamento contrario ai principi
>>> dettati
>>> solely
>>> confidential
>>> Protection
>>> reproduction,
>>> partial, is
>>> sender does
>>> or
>>> changes
>>> result of
>>> >>>> On 21 dicembre 2017 17:43, Francesco Bartoli <xbartolone at gmail.com>
>>> >>>> wrote:
>>> >>>>> Hi devs,
>>> >>>>> as 2.7.x became quite stable we should be ready to move to
>>> releasing
>>> >>>>> 2.8.0 as new stable version. Any feedback or concern?
>>> >>>>> At the moment we don’t have a release manager but Alessio, Angelos
>>> and
>>> >>>>> me can volunteer. However it’s likely we need some guidance to the
>>> overall
>>> >>>>> procedure.
>>> >>>>> Thanks and Merry Christmas to all of you
>>> >>>>> Francesco
>>> >>>>> _______________________________________________
>>> >>>>> geonode-devel mailing list
>>> >>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> >> Simone
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180215/49dbadcb/attachment-0001.html>
More information about the geonode-devel mailing list
