[GeoNode-devel] geonode-devel Digest, Vol 37, Issue 21
Simone Dalmasso simone.dalmasso at gmail.com
Thu Feb 15 06:52:12 PST 2018
Thanks a lot Thomas, so we need to update the package.
2018-02-14 23:43 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
> Simone,
> with the awesome-slugify package there was an issue(https://github.com/
> dimka665/awesome-slugify/pull/22) in its GitHub repo that was supposed to
> fix the ImportError. However in the awesome-slugify PyPy package I don't
> see the fix implemented. What I did for myself was pip uninstall
> awesome-slugify then I installed awesome-slugify from its GItHub repo (The
> Github repo has the fix). I used the command: pip install
> https://github.com/dimka665/awesome-slugify/archive/master.zip
> This worked for me.
> Thanks,
> -Tom
> On Wed, Feb 14, 2018 at 9:51 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> ok thanks Tom! definitely we have to fix this as will affect all pip
>> installations.
>> 2018-02-14 15:46 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
>>> sorry I mis-typed. What I meant to say is that in the django-polymorphic
>>> GitHub repo <https://github.com/django-polymorphic/django-polymorphic>,
>>> it says for *older Django versions than 1.11, install
>>> django-polymorphic==1.3.*
>>> I think that right now the 'django-polymorphic>=0.9.2' requirement
>>> installs a version of django-polymorphic newer than version 1.3, which
>>> requires Django version 1.11 or higher, which we don't want.
>>> On Wed, Feb 14, 2018 at 8:00 AM, Simone Dalmasso <
>>>> Dear Tom,
>>>> GeoNode 2.6 runs with Django 1.8 so we need to stay with it. I'm
>>>> wondering why the 1.11 is installed.
>>>> Silvia and others also ran in the issue with slugify lately so we need
>>>> to investigate what happens there. We haven0t changes the 2.6.x as far as I
>>>> know so something must have changed in the dependencies.
>>>> 2018-02-14 12:54 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
>>>>> I ran into the same issue you had today SILVIA.
>>>>> I noticed that for for the pypy GeoNode 2.6.1 package (
>>>>> https://pypi.python.org/pypi/GeoNode/2.6.1), the requirements.txt
>>>>> file lists django-polymorphic as
>>>>> However, as stated in the django-polymorphic GitHub repo,
>>>>> django-polymorphic==1.3 should be installed for Django 1.11.
>>>>> Can you try uninstalling django-polymorphic, and installing version
>>>>> 1.3?
>>>>> To all,
>>>>> Can we put 'django-polymorphic==1.3' in the requirements.txt for
>>>>> GeoNode 2.6.1?
>>>>> I am having problems now with awesome-slugify installing correctly,
>>>>> but I need think I need to look into this further.
>>>>> Thanks,
>>>>> Tom G.
>>>>> > On Feb 13, 2018, at 3:00 PM, geonode-devel-request at lists.osgeo.org
>>>>> wrote:
>>>>> > Send geonode-devel mailing list submissions to
>>>>> >       geonode-devel at lists.osgeo.org
>>>>> > To subscribe or unsubscribe via the World Wide Web, visit
>>>>> >       https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> > or, via email, send a message with subject or body 'help' to
>>>>> > You can reach the person managing the list at
>>>>> >       geonode-devel-owner at lists.osgeo.org
>>>>> > When replying, please edit your Subject line so it is more specific
>>>>> > than "Re: Contents of geonode-devel digest..."
>>>>> > Today's Topics:
>>>>> >   1. pkg_resources.VersionConflict when python manage.py      migrate
>>>>> >      (SILVIA GAMERO)
>>>>> >   2. Re: pkg_resources.VersionConflict when python manage.py
>>>>> >      migrate (Simone Dalmasso)
>>>>> > Message: 1
>>>>> > Date: Mon, 12 Feb 2018 16:09:15 -0600
>>>>> > From: SILVIA GAMERO <gamerinsky at gmail.com>
>>>>> > To: geonode-devel at lists.osgeo.org
>>>>> > Subject: [GeoNode-devel] pkg_resources.VersionConflict when python
>>>>> >       manage.py       migrate
>>>>> > Message-ID:
>>>>> >       <CAKjeEPWFkjQb9_EaOqEMCcdo+19tcZCMJymSQPcEHRdV7SiYZA at mail.g
>>>>> mail.com>
>>>>> > Content-Type: text/plain; charset="utf-8"
>>>>> > I have problems with geonode2.6x on Centos7, when migrating the data
>>>>> from
>>>>> > python manage.py migrate or try to start geonode ..
>>>>> > Traceback (most recent call last):
>>>>> >  File "/usr/lib/python2.7/site-packages/django/utils/autoreload.py",
>>>>> line
>>>>> > 229, in wrapper
>>>>> >    fn(*args, **kwargs)
>>>>> >  File
>>>>> > "/usr/lib/python2.7/site-packages/django/core/management/com
>>>>> mands/runserver.py",
>>>>> > line 107, in inner_run
>>>>> >    autoreload.raise_last_exception()
>>>>> line
>>>>> > 252, in raise_last_exception
>>>>> >    six.reraise(*_exception)
>>>>> line
>>>>> > 229, in wrapper
>>>>> >    fn(*args, **kwargs)
>>>>> >  File "/usr/lib/python2.7/site-packages/django/__init__.py", line
>>>>> 18, in
>>>>> > setup
>>>>> >    apps.populate(settings.INSTALLED_APPS)
>>>>> >  File "/usr/lib/python2.7/site-packages/django/apps/registry.py",
>>>>> line 85,
>>>>> > in populate
>>>>> >    app_config = AppConfig.create(entry)
>>>>> >  File "/usr/lib/python2.7/site-packages/django/apps/config.py",
>>>>> line 86,
>>>>> > in create
>>>>> >    module = import_module(entry)
>>>>> >  File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
>>>>> > import_module
>>>>> >    __import__(name)
>>>>> >  File "/usr/lib/python2.7/site-packages/polymorphic/__init__.py",
>>>>> line 13,
>>>>> > in <module>
>>>>> >    __version__ = pkg_resources.require("django-
>>>>> polymorphic")[0].version
>>>>> >  File "/usr/lib/python2.7/site-packages/pkg_resources.py", line
>>>>> 728, in
>>>>> > require
>>>>> >    needed = self.resolve(parse_requirements(requirements))
>>>>> 630, in
>>>>> > resolve
>>>>> >    raise VersionConflict(dist,req) # XXX put more info here
>>>>> > pkg_resources.VersionConflict: (Django 1.8.18
>>>>> > (/usr/lib/python2.7/site-packages), Requirement.parse('Django>=1.1
>>>>> 1'))
>>>>> > I followed the steps of the installation guide, although I commented
>>>>> that I
>>>>> > have not done the process that explain for the development mode, but
>>>>> > starting from the installation of postgres, tomcat, geoserver and
>>>>> finally
>>>>> > geonode.
>>>>> > With these same steps I had done a previous installation but I had
>>>>> problems
>>>>> > wanting to upload shapes to geonode or geoserver so I had to
>>>>> reinstall
>>>>> > everything again.
>>>>> > The version of Django that I am currently observing is the 1.8.18
>>>>> > I would greatly appreciate the help of someone who has already been
>>>>> able to
>>>>> > do the installation correctly.
>>>>> > -------------- next part --------------
>>>>> > An HTML attachment was scrubbed...
>>>>> > URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/
>>>>> 20180212/9f36e2e5/attachment-0001.html>
>>>>> > Message: 2
>>>>> > Date: Tue, 13 Feb 2018 07:20:16 +0100
>>>>> > From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> > To: SILVIA GAMERO <gamerinsky at gmail.com>
>>>>> > Cc: geonode-devel <geonode-devel at lists.osgeo.org>
>>>>> > Subject: Re: [GeoNode-devel] pkg_resources.VersionConflict when
>>>>> python
>>>>> >       manage.py migrate
>>>>> > Message-ID:
>>>>> >       <CAAHAC+cxy+tG9v3nSS9zLPGPnJhoo7y6HjvQ1NSE6LCbJT4OjQ at mail.g
>>>>> mail.com>
>>>>> > Hi, your django version is correct but looks like other libraries
>>>>> are not,
>>>>> > like polymorphic. I suggest to run pip install -r requirements.txt
>>>>> again.
>>>>> > 2018-02-12 23:09 GMT+01:00 SILVIA GAMERO <gamerinsky at gmail.com>:
>>>>> data from
>>>>> >> line 229, in wrapper
>>>>> >>    fn(*args, **kwargs)
>>>>> >>  File "/usr/lib/python2.7/site-packages/django/core/
>>>>> >> management/commands/runserver.py", line 107, in inner_run
>>>>> >> line 252, in raise_last_exception
>>>>> >>    fn(*args, **kwargs)
>>>>> 18, in
>>>>> >> setup
>>>>> line
>>>>> >> 85, in populate
>>>>> line 86,
>>>>> >> in create
>>>>> >> import_module
>>>>> >>    __import__(name)
>>>>> line
>>>>> >> 13, in <module>
>>>>> 728, in
>>>>> >> require
>>>>> 630, in
>>>>> >> resolve
>>>>> >> Requirement.parse('Django>=1.11'))
>>>>> commented that
>>>>> >> I have not done the process that explain for the development mode,
>>>>> but
>>>>> finally
>>>>> >> geonode.
>>>>> >> problems wanting to upload shapes to geonode or geoserver so I had
>>>>> to
>>>>> >> reinstall everything again.
>>>>> able
>>>>> >> to do the installation correctly.
>>>>> >> _______________________________________________
>>>>> > Simone
>>>>> 20180213/365c2a0e/attachment-0001.html>
>>>>> > Subject: Digest Footer
>>>>> > End of geonode-devel Digest, Vol 37, Issue 21
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180215/81230b83/attachment-0001.html>
More information about the geonode-devel mailing list
