[GeoNode-devel] Move to Release 2.8
Jonathan Doig j.doig at unsw.edu.au
Sun Feb 18 22:41:33 PST 2018
Hi Alessio/list
I have a working 2.8 system, installed using the steps Alessio outlined below (although see issue #3630<https://github.com/GeoNode/geonode/issues/3630> and my comment<https://github.com/GeoNode/geonode/issues/3628#issuecomment-366563173> on #3628).
This installs geonode into /usr/local/lib/python2.7/dist-packages/geonode, which is not suitable for patching and development (right?).
Are there currently working instructions for installing as a project for local development rather than just testing?
Is this tutorial (marked “2.6”) up-to-date for 2.8 (aka 2.7.x) with package versions, OAuth etc?
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
Or is there a simple procedure to change my 2.8 test build into a development build?
Regards
Jonathan
Sent: Thursday, 8 February 2018 3:35 PM
To: 'Alessio Fabiani' <alessio.fabiani at geo-solutions.it>; Paolo Corti <pcorti at gmail.com>
Cc: geonode-devel <geonode-devel at lists.osgeo.org>
Subject: RE: [GeoNode-devel] Move to Release 2.8
Hi Alessio
Just to confirm those steps worked flawlessly today on Amazon Web Services EC2 ‘t2.xlarge’ (16 GB RAM, 4 cores).
(I just find I need to first finish the AWS server set-up by adding this as line 2 in /etc/hosts:
127.0.1.1 ip-NNN-NNN-NNN-NNN
where NNN.NNN.NNN.NNN is my server’s private IP.)
I see many errors in the chrome dev console, but I can upload a layer and edit feature geometry via a map, so that’s a good start. Well done!
Regards
Jonathan
From: geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] On Behalf Of Alessio Fabiani
Sent: Saturday, 20 January 2018 12:20 AM
To: Paolo Corti <pcorti at gmail.com<mailto:pcorti at gmail.com>>
Cc: geonode-devel <geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>>
Subject: Re: [GeoNode-devel] Move to Release 2.8
Release process ongoing.
For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04 instance just run the following commands
sudo add-apt-repository ppa:geonode/testing
sudo apt update
sudo apt install geonode
geonode createsuperuser
IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
sudo geonode-updateip $IP_ADDRESS
sudo service apache2 restart
This is still under testing, so 1. do not try this on production servers - or on server where you have installations you don't want to break ; 2. it is possible that something goes wrong - in this case please report to me
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
2017-12-23 11:29 GMT+01:00 Paolo Corti <pcorti at gmail.com<mailto:pcorti at gmail.com>>:
+1!
of course
Paolo
On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
<xbartolone at gmail.com<mailto:xbartolone at gmail.com>> wrote:
> Hi Rizky,
> yes you should backport it to 2.7.x which will become 2.8.0 then.
> Ciao
> Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
> <rizky at kartoza.com<mailto:rizky at kartoza.com>> ha scritto:
> +1
> Can I also know how are you going to release 2.8? Is it coming from 2.7.x
> branch? I would like to include qgis-server backend if possible, but that
> depends on how much effort that would be. At the moment, only master branch
> have qgis-server backend.
> Software Developer
> Kartoza.com
> On Dec 22, 2017 02:15, "Tom Kralidis" <tomkralidis at gmail.com<mailto:tomkralidis at gmail.com>> wrote:
>> +1
>> ..Tom
>> Sent from my iPhone
>> On Dec 21, 2017, at 14:13, Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
>> wrote:
>> +1!
>> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <jcooper at jeremiahcooper.com<mailto:jcooper at jeremiahcooper.com>>:
>>> +1.
>>> Thanks.
>>> Jeremiah Cooper
>>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>> <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>> wrote:
>>>> +1
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> phone: +39 0584 962313<tel:%2B39%200584%20962313>
>>>> fax:     +39 0584 1660272<tel:%2B39%200584%201660272>
>>>> mob:   +39 331 6233686<tel:%2B39%20331%206233686>
>>>> http://twitter.com/geosolutions_it
>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>>>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>>>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>>>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>>>> finalità diverse, costituisce comportamento contrario ai principi dettati
>>>> dal D.Lgs. 196/2003.
>>>> On 21 dicembre 2017 17:43, Francesco Bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>
>>>> wrote:
>>>>> Hi devs,
>>>>> as 2.7.x became quite stable we should be ready to move to releasing
>>>>> 2.8.0 as new stable version. Any feedback or concern?
>>>>> At the moment we don’t have a release manager but Alessio, Angelos and
>>>>> me can volunteer. However it’s likely we need some guidance to the overall
>>>>> procedure.
>>>>> Thanks and Merry Christmas to all of you
>>>>> Francesco
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180219/dbec14d6/attachment-0001.html>
More information about the geonode-devel mailing list
