[GeoNode-devel] [GeoNode-users] ☞ GeoNode 2.8 vagrant base box & video walkthrough ☜
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jul 3 00:28:10 PDT 2018
Great Job Toni,
we should make it working with new release also.
Any chance to port it on official repos?
Il giorno mar 3 lug 2018 alle ore 08:34 Dimitris Karakostis <
karakostis.dimitris at gmail.com> ha scritto:
> Great job.
> Thanks.
> On Mon, Jul 2, 2018 at 11:26 PM, Jac Steiner <jackrsteiner at gmail.com>
> wrote:
>> very cool
>> On Tue, Jul 3, 2018 at 3:52 AM, Toni Schönbuchner <
>> toni.schoenbuchner at csgis.de> wrote:
>>> Dear GeoNode Community,
>>> recently questions regarding howto install GeoNode from source as
>>> project [1] in dev or production
>>> environment popped up.
>>> VIRTUAL MACHINE
>>> To get you started or even for workshops and trainings find here a fully
>>> configured
>>> geonode 2.8 vagrant base box (Provider: virtualbox)
>>> > https://app.vagrantup.com/t-book/boxes/geonode_28_base/versions/1.0.0
>>> To use this instance make sure you´ve installed virtualbox and vagrant
>>> and create a file
>>> called Vagrantfile with following content:
>>> > https://gist.github.com/t-book/7ae41929b22ec84abe97d13f1c338cd6
>>> From the same directory in a terminal run
>>> > vagrant up && vagrant ssh
>>> This downloads the box, configures the network and starts a fresh ssh
>>> session.
>>> Vagrant provisions the network with address: 192.168.33.14.
>>> In case you need to change it:
>>> 1) edit the IP in your Vagrantfile
>>> 2) change the ip in ALLOWED_HOSTS see:
>>> /home/geonode/my_geonode/my_geonode/local_settings.py
>>> 3) correct the oauth2 part of geoserver as shown in following video.
>>>  VIDEO
>>> I´ve screen recorded and commented the whole setup for you:
>>> > https://vimeo.com/278003647
>>> > *Get yourself a full bottle of coffee it’ll be lengthy and boring ;) *
>>> The Installation process is quite close to the installation guide with
>>> following differences:
>>> > the sudo user from the docs GEO is here called vagrant
>>> > the docs use virtualenvwrapper to setup the virtualenv, I´m directly
>>> using virtualenv
>>> > Errata: Around minute 7:30 my comment says pygdal 2.3.1.3 where it
>>> should say 2.2.1.3
>>> > I´ve recognized the first line of the terminal is cut off ;(
>>>    But as I copy the commands from the documentation it should not be
>>> hard to follow.
>>> Last but not least, please be lenient if you find spelling mistakes in
>>> my comments
>>> ! multitasking !
>>> && please help to save our planet.
>>> https://en.wikipedia.org/wiki/Great_Pacific_garbage_patch
>>> Cheers,
>>> – Toni
>>> [1]
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html#
>>> https://www.virtualbox.org/
>>> https://www.vagrantup.com/
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198
>>> Tel  +49/ (0) 341 24 04 738
>>> Fax  +49/ (0) 341 24 04 73
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180703/20dbe8ba/attachment-0001.html>
More information about the geonode-devel mailing list
