[GeoNode-devel] GeoNode Demo instance up and running
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 22 01:46:06 PDT 2018
Great news! Thanks a lot to all!
Il giorno ven 22 giu 2018 alle ore 10:05 G. Allegri <
giovanni.allegri at geo-solutions.it> ha scritto:
> Dear devs,
> we're pleased to announce that an instance of the master GeoNode branch
> has been published on our servers. It will serve as a demo of the latest
> (development) version of GeoNode.
> The instance is running on Docker. Every night the containers are
> restarted from scratch. Data uploaded from users, maps and any other
> configuration will be reset. Only users accounts are retained between
> restarts.
> For the moment the GeoNode image is built manually every two weeks. We did
> some tests with automatic pull / build but master code is too much
> "volatile" to guarantee CI. This is a topic by itself that we suggest to
> discuss in a dedicated thread.
> We invite everybody to test it and give us feedbacks.
> In a week since now we will publish the link on the demo landing page (
> http://demo.geonode.org).
> *Master GeoNode Demo URL: http://master.demo.geonode.org
> <http://master.demo.geonode.org/>*
> All the best,
> Giovanni
> Giovanni Allegri
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
>  (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180622/649f8ad0/attachment.html>
More information about the geonode-devel mailing list
