[GeoNode-devel] GeoNode Demo instance up and running
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jun 22 06:06:17 PDT 2018
Example embed map generated on demo instance
http://master.demo.geonode.org/maps/6/embed
Il giorno ven 22 giu 2018 alle ore 10:46 Simone Dalmasso <
simone.dalmasso at gmail.com> ha scritto:
> Great news! Thanks a lot to all!
> Il giorno ven 22 giu 2018 alle ore 10:05 G. Allegri <
> giovanni.allegri at geo-solutions.it> ha scritto:
>> Dear devs,
>> we're pleased to announce that an instance of the master GeoNode branch
>> has been published on our servers. It will serve as a demo of the latest
>> (development) version of GeoNode.
>> The instance is running on Docker. Every night the containers are
>> restarted from scratch. Data uploaded from users, maps and any other
>> configuration will be reset. Only users accounts are retained between
>> restarts.
>> For the moment the GeoNode image is built manually every two weeks. We
>> did some tests with automatic pull / build but master code is too much
>> "volatile" to guarantee CI. This is a topic by itself that we suggest to
>> discuss in a dedicated thread.
>> We invite everybody to test it and give us feedbacks.
>> In a week since now we will publish the link on the demo landing page (
>> http://demo.geonode.org).
>> *Master GeoNode Demo URL: http://master.demo.geonode.org
>> <http://master.demo.geonode.org/>*
>> All the best,
>> Giovanni
>> Giovanni Allegri
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>>  (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
mob:   +39 331 6233686
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180622/c540d1e0/attachment-0001.html>
More information about the geonode-devel mailing list
